Distributor CYP Help!!!
Old Dec 3, 2014 | 04:53 PM
carlos8's Avatar
Default Distributor CYP Help!!!
hi, I recently bought a OEM JDM distributor with 40k, replaced the rotor and cap with original parts. Yesterday the rotor screw back off and hit the CYP (not have the plastic shield). Now the car start but with code 9, I have the old dizzy with good CYP.
Someone can give me a link or a idea on how to swap them... I've heard people like hondapartshero saying that there are interchangeable.
thanks
P.S. The dist. is a TD87 from a ITR but here I can get more help.
Old Dec 3, 2014 | 06:45 PM
Former User's Avatar
Default Re: Distributor CYP Help!!!
Once you fix the sensor, install a dust cover, which is not an optional distributor component.
Old Dec 6, 2014 | 06:46 AM
carlos8's Avatar
OK, Replaced the CYP and the Code 9 still on. Switch to an eBay distributor and the code not show. The reason I can't leave the eBay distributor on is cause it breaks in High boost.
CYP have 402 ohms (in spec). What other thing can trigger the code 9?
Thanks
Old Dec 6, 2014 | 08:44 AM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/honda-civic-d...-fire-2839749/
Old Dec 6, 2014 | 12:10 PM
carlos8's Avatar
No, sorry for use your name as example, I just referring in my case two same models distributors can exchange guts.
My doubt was about the alignment of the sensor, but once I take it off I see the pin in the back.
Any advice on the code 9 once replaced the CYP?
Old Dec 7, 2014 | 03:32 AM
Technical Hero
Read the link I posted it has the troubleshooting for code 9
Old Dec 8, 2014 | 11:09 AM
carlos8's Avatar
Perform all the test from the manual. Still code 9.
CYP = 402 ohms
TDC = 376 ohms
CKP = 369 ohms
Tested at distributor plug and computer plug.
Continuity test to body ground also in both ends.
The code not show the first minutes at cold start, when the CEL pop on, turn off the car and start it again and the CEL stay off like 10 seconds and pop again. Put another distributor and no CEL.
Old Dec 8, 2014 | 03:21 PM
Technical Hero
Get another OEM distributor
Old Dec 9, 2014 | 11:03 AM
tamboo's Avatar
10 Year Member
or find a used one that's tested good.
Car-Part.com--Used Auto Parts Market
psycho.chicken
Jul 21, 2006 09:34 AM
PaChiLa Leader
Oct 10, 2005 09:38 AM
staticrex
Jun 9, 2004 12:13 PM
Reddog
Aug 28, 2002 01:24 PM
