Pic for those of you who bought my earthing system...
Old Nov 2, 2002 | 08:31 AM
Tommy_Gunns's Avatar
Default Pic for those of you who bought my earthing system...
I know alot of you don't visit the classifieds section so I'm posting this here for the group of people who ordered an earthing system from me.
I've begun production of the kits. The ends have not been soldered yet in this pic but will be soldered before shipping.
Here is a pic of what you will recieve:
Here is a link to the thread in the classifieds section:
https://honda-tech.com/zerothread?id=322005
IM me if you have questions or post the question in the classifieds thread.
[Modified by Tommy_Gunns, 12:03 PM 11/2/2002]
Old Nov 2, 2002 | 09:31 AM
Mike M's Avatar
Founding Member
Default Re: Pic for those of you who bought my earthing system... (Transition)
This is in BOLD so if anyone doesn't read and follow it they have NO Excuses.
1st and ONLY Warning. Tommy_Gunns is doing this at a VERY good price for those who don't feel like making their own or don't have the time. IF <u>YOU</u> Don't like it, Think you can make it cheaper, think it doesn't work etc. DON'T Bother posting. If you do start posting Negative comments I will deduct 1% from each Negative post as well as delete it.
Tommy_Gunns good luck on your sale
Old Nov 2, 2002 | 09:39 AM
Mike M's Avatar
Founding Member
Default Re: Pic for those of you who bought my earthing system... (Mike M)
PS Cleaned up some of the unneeded posts directed at that last moron.
Old Nov 2, 2002 | 09:42 AM
(__________)'s Avatar
&lt;----lazy man right here, I ordered one
Boo439's Avatar
Default Re: Pic for those of you who bought my earthing system... (Tommy_Gunns)
The kit looks real nice, I can't wait to get mine. Thanks!
Old Nov 2, 2002 | 09:43 AM
sneakychaos's Avatar
Down boy. Someone had a bad weekend.
Old Nov 2, 2002 | 09:46 AM
Mike M's Avatar
Founding Member
Default Re: Pic for those of you who bought my earthing system... (sneakychaos)
LOL Actually a GREAT weekend so far Just hate seeing that crap everytime this guy makes a post.
Old Nov 2, 2002 | 09:49 AM
good move
Old Nov 2, 2002 | 09:54 AM
itr1244's Avatar
hey~ i am interested.. any more left?
let me know~
Old Nov 2, 2002 | 10:12 AM
mikeSONICGSR's Avatar
What exactly is the earthing system, what does it do?
Old Nov 2, 2002 | 10:55 AM
Nameless RB26's Avatar
Default Re: Pic for those of you who bought my earthing system... (mikeSONICGSR)
Looks like you did a good job making them.
Maybe when I get some money someday, I can order one from you.
Old Nov 2, 2002 | 10:58 AM
Eric R's Avatar
Like its name says, these cables allows to properly ground many different parts in your engine and engine compartment so it improves the functioning of key elements in the performance of your vehicle. One of the benefits is that it improves throttle response when it grounds better the ignition system components.
Edit: Wow, my English is improving...
[Modified by Tweety R, 12:00 PM 11/2/2002]
Old Nov 2, 2002 | 11:14 AM
Big Teggie's Avatar
Looks pretty good
I think I may have to get it.
Old Nov 2, 2002 | 11:37 AM
baonest1's Avatar
Default Re: Pic for those of you who bought my earthing system... (Big Teggie)
hey tweety thanx fer the expl. ive been wondering the same thing.. what are some parts that need to be grounded?? arent all the parts already grounded?
thanx
Old Nov 2, 2002 | 11:38 AM
Soldered for a better longer lasting connection. The double wire end looks a little messier because it is difficult to heat up such a thick piece of metal.
Old Nov 2, 2002 | 11:48 AM
Dave-ROR's Avatar
Looks good tommy.
I need to replace my stock ones once I do all the other crap to my car (clutch, tbelt/tens/wpump, tuneup, vadj, etc). Maybe I'll do a few extra wires..
Mike M: I was really really tempted to talk **** because of your post btw haha
Old Nov 2, 2002 | 11:54 AM
Zeus's Avatar
Moderator of the year award goes to YOU! hope the rest of them pay attention and start weeding out all this needless bickering and bitching!
Looks good Tommy... I'll be in touch...
Old Nov 2, 2002 | 12:03 PM
mstewar's Avatar
looks good man.. can't wait to get mine.. thanks!
Old Nov 2, 2002 | 12:09 PM
tonyxcom's Avatar
Tommy, you need a stronger soldering iron. At least 40-60 Watts with a large tip. I can tell just by the look of those solders that they didn't get no where near hot enough. I have an iron that can keep a puddle or solder as bigas a paper plate hot and flowing. It cost 200 bux though.
Goto home depot and look for an orange soldering iron that cost about 20 bux. It is made by weller. The tip dont last long, but the iron is 40 watts. Use that. It will work.
Then when you notice the tip starting to deteriorate, let the iron cool off then file it back to its original shape. The solder should look like its still wet after its dry. That is how you know you have a good joint.
[Modified by tonyxcom, 9:09 PM 11/2/2002]
Old Nov 2, 2002 | 12:21 PM
Mike M's Avatar
Founding Member
Default Re: Pic for those of you who bought my earthing system... (Zeus)
Thanks
Tommy you might want to either pick up a Stronger Soldering Iron Or to heat up the connectors use a Butane Lighter and then the soldering iron.
Old Nov 2, 2002 | 12:32 PM
Default Re: Pic for those of you who bought my earthing system... (tonyxcom)
I'm using a 100W soldering gun. The 8 gauge single terminal soldering connections are perfect, you can tell by the fact that you can see the individual strands. The double ended connections although not as perfect, are very good as well.
Old Nov 2, 2002 | 01:06 PM
BrandonClaps's Avatar
New User
may i make a suggestion to make it easier on you. I know when i did a stereo install with 0 gauge wire, i used like a little blow torch thingy (crack torch) i guess people call them. Heat up the wire and just push the solder into it, it will flow evenly and is alot less work. Works VERY VERY well. I suggest you try that.
Old Nov 2, 2002 | 01:22 PM
Default Re: Pic for those of you who bought my earthing system... (BrandonClaps)
update on the soldering...I changed tips and now it is working beautifully. You can see individual strands on the double wire connection which indicates a very good solder.
Old Nov 2, 2002 | 01:29 PM
New User
so my idear worked?
Old Nov 2, 2002 | 01:31 PM
so my idear worked?
No, I'm still using my 100W soldering gun, I just changed tips and it is working beautifully.
The torch idea sounds great but the people in the house would kill me and it is too cold to work outside...plus I don't own a torch.
