NEED HELP!!FOR PPL WITH TRUBO CARS
Old Nov 30, 2014 | 04:54 PM
nickem1boosted's Avatar
Default NEED HELP!!FOR PPL WITH TRUBO CARS
hello guys my name is nick i been in the honda game for a while and i just turbo my em1 and to make a long story short i need help with it , my tuner was chris miller and my build was done local from a shop and friends , ok so i got the car after dyno was working fine until , i started driving for a week and i notices the car would hesitate when i would let go of the gas and press down, like it was choking , and i i check the tps sensor which was a lil loose so i tighten it back up and i still get that hesitate feeling ,what do you guys think it can be , the only think i have stock in the car is the motor mounts which i would be getting replace soon PLEASE HONDA TECH NEED FOR YOUR HELP
Old Nov 30, 2014 | 10:02 PM
siblues's Avatar
Default Re: NEED HELP!!FOR PPL WITH TRUBO CARS
I had a similar issue but my car was running an AEM ems.It was just some small tuning issues.What is your car tuned on?
Old Dec 1, 2014 | 05:14 AM
LTCxD2B's Avatar
It's probably the throttle tip in value ... When u let off and then hit the gas.. That initial burst of fuel is from the throttle tip in
Old Dec 5, 2014 | 05:37 AM
My car is running on 92 pump gas i just oder the tps sensor I'm going to be instilling it today I hope it works , and also my rmp right now are idiot a lil high u think if I adjust that it will effect the tune or make it offset in any way ?
Old Dec 5, 2014 | 05:39 AM
[QUOTE=LTCxD2B;50084804]It's probably the throttle tip in value ... When u let off and then hit the gas.. That initial burst of fuel is from the throttle tip
i just oder the tps sensor I'm going to be instilling it today I hope it works , and also my rmp right now are idiot jumping up and down a lil high u think if I adjust that it will effect the tune or make it offset in any way ?
Old Dec 5, 2014 | 07:38 AM
LTCxD2B's Avatar
I assumed u had already adjusted it correctly and set the max and min values in the software if not set the tps to factory spec or it'll drive like crap
Jun 9, 2007 09:02 AM
B16Civic93
Apr 28, 2005 05:09 PM
DjFreeze
16
Apr 13, 2004 09:40 AM
