A look at Ericks Racing new Products!!!
A new design of Ericks racing new 2.2L piston (will be available for Racing use only ) do the hight CR 15.1-16.1 ,which he will be using a stroker kit for more displacement ...
Erick's Racing Exhaust Header
Header shot on dyno
Here is a dyno comparison of Ericks header vs a JDM Type-R header:
The header gains power mainly from 7500 rpm onwards.
[Modified by Spoon1, 4:36 PM 11/2/2002]
Header shot on dyno
there new(pistons) and he gave me the pics to post them up and show you guys some of his new things to come
what is his stroker kit going to consist of cause those pistons need alot more to run than just a bolt on...
what the hell do you have to do to the head bowl/quench area to get that dome to work? Say bye bye to your chamber (capture) volume.
what the hell does a cam have to do with the head bowl that aligns with the dome?
and those are obviously race-only pistons since they are strutted. The lack of piston skirt area reduces frictional drag and save weight but they must run pretty tight piston to wall clearances and wear the ringlands/rings.
are those pistons phosphate coated like the Mahle pistons to shorten the break in period?
[Modified by Michael Delaney, 11:48 PM 11/2/2002]
I would have thought with all of those twists and turns on that header's primaries that you would have seen some more hains in the midrange but the fact that it only starts breathing until 7500 rpm may be due to the 2 in. diameter those primaries have right off the bat.
That NRG Tech header which also has similar primaries twists and turns has a stepped smaller diameter out of the flange and would be interesting to see how it performs in the useable powerband.
also if you know already, piston design is very closely related to camshaft specs, that's why a high domed piston is necessary for a very aggresive cam in a combustion chamber already designed to flow air from a domed piston as opposed to milling the head or welding in the combustion chamber.
