94 Civic DX coupe with D15B7 engine - Crankshaft pulley tool
Old Nov 29, 2014 | 03:01 PM
tomcatter1962's Avatar
Default 94 Civic DX coupe with D15B7 engine - Crankshaft pulley tool
I have a 1994 Civic DX coupe with a D15B7 engine in it. The car has 203178 miles on it. I bought the car back in 2002 for my oldest daughter. The car was wrecked in 2006. The car sat in my yard until this summer. I have done body work and paint. doing mechanical work on it now. Started doing the timing belt today. I rented the crankshaft pulley holder. It has 6pt shape on the tool. I noticed that my crankpulley does not have the 6pt to interface with the tool. My pulley is shaped like a bowl. It has holes around the circumference for the pulley. Any ideas on how to remove the bolt from the pulley bolt from the crankshaft would be greatly appreciated.
Respectfully
Old Nov 29, 2014 | 03:08 PM
Former User's Avatar
Default re: 94 Civic DX coupe with D15B7 engine - Crankshaft pulley tool
Wilmar W89209 Crank Pulley Holding tool - Tools Auto - Amazon.com Wilmar W89209 Crank Pulley Holding tool - Tools Auto - Amazon.com
Old Nov 29, 2014 | 03:12 PM
92ehatch's Avatar
I used an 8mm Allen key on mine. Craftsman the cheap ones bend.
This method will dent the edge of the oil pan where it bolts up Better off with the right tool but this method will work
Old Nov 29, 2014 | 03:26 PM
Default Re: 94 Civic DX coupe with D15B7 engine - Crankshaft pulley tool
Thanks RonJ@HT i will look at the parts stores
Old Dec 2, 2014 | 01:12 PM
24TEN's Avatar
PHANTOM MENACE
You can also try with someone sitting in the car pressing the brake pedal while in park or in gear.
Old Dec 4, 2014 | 11:14 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Without the aid of the brake booster you really have to have hulk legs to get any real grip on the rotors. Even then it tends to slip or so I found when popping my axle nuts.
For a crank pulley you can't run the car to make use of the brake booster so most likely even with someone mashing the brakes with all their might, it's probably going to not be very effective.
Old Dec 5, 2014 | 09:27 AM
24TEN's Avatar
PHANTOM MENACE
You should know I HAVE hulk legs then. (LOL)
Old Dec 5, 2014 | 09:41 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Old Dec 6, 2014 | 03:11 AM
To give an update, I ordered the crank pulley holder tool from Amazon, and used it last night. it worked like a champ. No issues. Thanks RonJ@HT and all who responded!
Repectfully
Old Dec 6, 2014 | 10:22 AM
tamboo's Avatar
10 Year Member
i just insert a big screwdriver into the brake rotor slot next to the caliper,
pressing on the brake pedal is for the birds (or hulks).
Wytas
Oct 13, 2018 10:19 AM
hcaulfield57
21
Jul 30, 2017 04:55 PM
zrs6v4
Feb 16, 2016 11:57 AM
jonnythan
14
Nov 27, 2008 09:53 AM
TorquelessB16
48
May 24, 2006 02:44 AM
