Used 1990 Honda Accord Maintainence
Old Nov 29, 2014 | 11:04 AM
BrownProdigy's Avatar
Icon2 Used 1990 Honda Accord Maintainence
Hey guys i just bought my first car. Its a 1990 Honda accord ex with 270000km. I have about $400 to spend in preventative maintenance, What do you recommend to do? . Do i need to check for specific failure prone components? Also how is its general reliability? Thnx in Advance!
Old Nov 29, 2014 | 11:13 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Used 1990 Honda Accord Maintainence
Assuming the major maintenance has been completed (timing belt/water pump/etc) then I'd recommend looking at fluids (coolants, transmission, engine, brake, power steering, etc)your brakes, bushings, etc and identify worn out components.
Old Nov 29, 2014 | 11:14 AM
rockycat's Avatar
Timeing belt and water pump if you do not know when they were replaced.
Old Nov 29, 2014 | 11:26 AM
Thnx for the replies. The timing belt and water pump were replaced 40000km ago. So i dont think it would need changing now. Ill inspect and probably replace the fluids. Thnx Again
Old Dec 4, 2014 | 02:41 PM
ZDOG2KXX's Avatar
Hey guys, I drive a 90 Accord EX and is my first car, is it a problem when i'm driving before the car is warmed up and it slightly idle searches? Like between 100-150 rpms? once the car is warm, it only shakes, and is not audible.
Old Dec 4, 2014 | 03:15 PM
rockycat's Avatar
Zdog, this is not your thread so open one of your own and you will get help.
Old Dec 5, 2014 | 10:16 PM
Treyschls's Avatar
valve adjustment, check ignition timing, set idle screw, distributor rotor & contacts
xemi
Oct 17, 2018 08:03 AM
aschweizer2007
Sep 21, 2018 07:22 PM
f22b2guy
Feb 1, 2008 03:54 PM
Stew Pidasso
Jan 2, 2008 04:41 AM
jaspaly
Oct 2, 2006 08:30 AM
