Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
cylinder 4 misfire
Old Nov 29, 2014 | 09:47 AM
mcannon's Avatar
Default cylinder 4 misfire
I have a 2003 civic ex that in the past 6 months is a complete dog/no power with a cylinder 4 misfire. I have changed the spark plugs, #4 coil, and #4 fuel injector. None of these have fixed the sluggishness or code. I have not done a compression check and it has not had the timing belt done yet. I am getting frustrated with the problem. I would appreciate any suggestions. Thanks!
Old Nov 30, 2014 | 10:54 AM
spdracrm3's Avatar
Default Re: cylinder 4 misfire
only other things that you haven't changed that could cause single cylinder misfire are vacuum leak or compression related issue (possibly tight/burned valves?) or a bad ECM /wiring between ECM and coil(causing coil to not fire).
last but not least blown headgasket....
i say start with compression test to know engine baseline is good , then smoke test for vacuum leak, then advanced testing with scope will be required to test ECM/wiring/coil output
bsconz
Sep 20, 2012 06:10 AM
civic90hatch
Mar 16, 2011 01:09 PM
turboD_EG
Apr 17, 2009 07:19 AM
team 15
Jan 12, 2007 03:27 PM
LSVTEC 91 Civic
25
Jul 12, 2004 01:49 AM
