skunk2 manifold with blox tb...install questionn
Old Nov 28, 2014 | 11:37 PM
Crazyycivic98's Avatar
Default skunk2 manifold with blox tb...install questionn
whats up...i just install my skunk2 mani and a blox tb...everythings is fine everything is connected..but when i installed the skunk mani the car sounds like its running open headers..(wich my pipe is not connected,its like a inch away from down pipe and and the exhuast pipe...but it was fine with my old mani sounded normal) the car runs good other when im around 3k rpms and up it like hesitates but it wont turn off or anything and it runs good...my other question is that do i have to tune..i had tune the car before w 310ccinjectors.....thanks for the helpp
Old Nov 29, 2014 | 02:09 AM
B_Swapped93's Avatar
Default Re: skunk2 manifold with blox tb...install questionn
at the very least a basemap but wait ill you have everything on the car that you want before getting it properly tuned. or you'll be throwing $500 away each time, changing the intake manifold is a bigger deal then the exhaust manifold so in short yes you should get it properly tuned once you have everything done.
Header*** its an inline 4 not a V
Old Nov 29, 2014 | 07:54 AM
yea i should done that becuase my basemap was tune with my stock manifold...but for know its just a manifold till i save up for more things...
but nothng bad will happen...its just burning fueel and smells...i will tune it in a week or 2...
Old Nov 29, 2014 | 12:00 PM
EsotericImage's Avatar
Retired Moderator
yea, you just cant throw in new injectors that flow 35%+ more then stock an expect it to run right.. your ******* it up and washing down the walls
Old Nov 29, 2014 | 12:43 PM
my car was tune with those 310 injectors bro...
Bserious
42
Sep 19, 2012 11:39 AM
djteggy99
Feb 27, 2009 08:05 AM
0evilEMPIRE0
Mar 15, 2004 06:22 AM
InteGRL
Jul 13, 2001 08:43 PM
