Vacuum lines
Old Nov 27, 2014 | 08:25 PM
90R3x's Avatar
Default Vacuum lines
Will this diagram work on a b18a1
Old Nov 28, 2014 | 01:47 PM
90R3x's Avatar
Default Re: Vacuum lines
Anyone... help please i need a diagram with out the pressure regulator cut off solenoid valve, I've done research and can't find anyting. Can someone please help me with a diagram i am just really confused thanks.
Old Nov 29, 2014 | 03:18 PM
BADFISH859's Avatar
few questions! are you running a throttle body with a mass airflow sensor on the top? also, do you want to keep the charcoal canister?
Old Nov 29, 2014 | 03:19 PM
BADFISH859's Avatar
fuel pressure regulator vacuum source should be on the front of the intake manifold. pick any of them.
Old Nov 29, 2014 | 03:27 PM
BADFISH859's Avatar
canister can be completely removed from the car! Run a vacuum line from port on top center of throttle body to the firewall that was going to the charcoal canister. the other thing top right in the picture you provided is the maf sensor. if your throttle body has one on top of it... unplug the unit from the firewall place in trash. Their is two plugs you'll unplug but only need one. it looks exactly like the tps plug. the other plug can be tapped back. plug that into the top sensor on your throttle body. If youre throttle body don't have a maf sensor... go buy one with it! hahaha
tbw that diagram should work with a b18
mitchh29
15
Mar 13, 2013 11:53 AM
B16A CRX
Mar 20, 2008 04:53 PM
prelude9999
Oct 8, 2004 10:01 AM
93NXLUDE
Aug 30, 2003 09:06 AM
