97 Civic ex front Camber - inner tire wear problem
Old Nov 27, 2014 | 05:13 AM
jorge74's Avatar
Default 97 Civic ex front Camber - inner tire wear problem
Hi i have an issue were the inner tires wears out within 4 months. I put New (Stock Height) complete struts, springs, mounts, ball joints (lower & upper ) upper contol arm plate, sway bar links, tie rods inner & outer still no luck 4 diffrent alignment shops they always say its within spec . Is there a camber bolt or something that can be added or what to do? Thanks
Old Nov 27, 2014 | 05:16 AM
Former User's Avatar
Default re: 97 Civic ex front Camber - inner tire wear problem
Is the suspension modified? If so, add info to first post.
Old Nov 27, 2014 | 05:22 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 97 Civic ex front Camber - inner tire wear problem
Toe is killing your tires. Not camber.
Old Nov 27, 2014 | 05:30 AM
EsotericImage's Avatar
Retired Moderator
The car might be in spec on the rack, but when you sit in it, it throws the alignment off.
They really should do it when your sitting in the car.
Old Nov 27, 2014 | 08:48 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
You may have a torn bushing in a control arm or something. Are the front or rear tires wearing that way? No...there aren't camber bolts for 88-00 civics.
Old Nov 27, 2014 | 09:11 AM
jorge74's Avatar
Nothing modified its all stock toe and camber according to alignment specs are with in . The rear i have adjustable upper and dont get any tire wear all tho lower one i cant adjust cause bolt is frozen in and will break so i cant adjust toe at rear unless a cut a piece from frame so i could put a bolt and nut there with adjustable lower.
Old Nov 27, 2014 | 09:17 AM
jorge74's Avatar
The Contol arm are new.
DISFORCFC
Jun 10, 2015 06:35 AM
RomesEM1
Suspension & Brakes
Sep 25, 2009 06:37 PM
numan1421
Jun 13, 2008 12:31 PM
EnjoyTheRideDC2
Mar 2, 2006 04:05 AM
Jason C SBB
Dec 29, 2003 08:34 PM
