99 Civic - Power Door Lock Issue
Old Nov 26, 2014 | 01:17 PM
dac55's Avatar
Default 99 Civic - Power Door Lock Issue
When i push my keyless remote my doors will barely lock, if at all. They won't unlock using remote Its like there is not enough power to make locks function by pressing the keyless button. everything works fine with manual key. i replaced the drivers actuator, replaced remote battery, checked fuses and keyless unit under driver kick panel to make sure its connected correctly. also have replaced battery and alternator recently. I've been using the key for a while now. just got around to finding keyless problem. any and all suggestions are welcome, thanks.
99 civic ex 2 door
Old Nov 26, 2014 | 01:28 PM
Former User's Avatar
Default Re: Door Lock Issue
Do the doors lock and unlock fine using the lock switch on the driver's door?
Old Nov 26, 2014 | 03:21 PM
dac55's Avatar
Default Re: 99 Civic - Power Door Lock Issue
Yes. The key locks and unlocks doors on both sides. The inside switch works to lock and unlock. It's only when using the keyless remote there is a problem. It moves the locks just barely. If I push it enough times it will lock and horn blows, but it takes 10+ times
Old Nov 26, 2014 | 03:26 PM
Originally Posted by dac55
Yes...The inside switch works to lock and unlock. It's only when using the keyless remote there is a problem. It moves the locks just barely. If I push it enough times it will lock and horn blows, but it takes 10+ times
This^ information tells you that the battery, actuators, and fuses are/were fine. The problem is probably the control unit itself. You can verify by doing the service manual input tests for the control unit.
Old Nov 26, 2014 | 05:04 PM
dac55's Avatar
Thanks for the info
thatcivic96
Audio / Security / Video
15
Jun 2, 2013 03:41 PM
deerman2701
Jun 14, 2011 05:58 PM
jaredvabeach
Aug 19, 2009 03:41 PM
SkyLinER
Mar 12, 2006 09:03 PM
