Honda Insight & CR-Z Hybrid Honda Insight and CR-Z Hybrid discussion forum.
K24 Insight
Old Nov 26, 2014 | 07:43 AM
Proawemike's Avatar
Default K24 Insight
Hello all,
I am gathering parts to put a K24 into an Insight. I have been gathering info from many different locations but wanted to know if there was a build thread or website that documented other peoples issues with the swap. Any help would be greatly appreciated.
Thanks,
Mike
Old Dec 2, 2014 | 06:33 AM
4piston's Avatar
Default Re: K24 Insight
Innovate makes a mount kit, although the rear mount could use some reinforcing. Its straight drop in with those mounts.
You need to get either EP3 or RSX knuckles, then choose a strut with a large shaft (required for Mcpherson strut) and make your own lower control arm to tie it all together. It isn't difficult and a chassis fab shop should be able to help.
Last of all, call Driveshaft shop and have them make you axles. You will have to take a measurement once the motor and suspension is in place.
Good luck.
Old Dec 2, 2014 | 07:41 AM
spAdam's Avatar
Loved
Community Favorite
LHT K-Sight
http://www.lhtperformance.net/documents/DSC00827.jpg
I still wish it were practical/possible to retrofit the IMA onto other motors... Sign me up for a K20/24 with regenerative braking and push to pass! A guy can dream, right?
They also did a KR-Z apparently, didn't know that. That's what happens when you stop reading the magazines I guess
Old Dec 4, 2014 | 12:32 PM
brian g's Avatar
The K with an IMA would be way too wide for the Insight's narrow frame rails. You'd have an easier time putting the V6 with IMA in.
Old Dec 8, 2014 | 06:20 AM
Proawemike's Avatar
Good luck.
4Piston,
The rear mount on the Innovate system is weak? Can you elaborate?
As for the knuckles and lower control arms I have seen people modify the RSX spindles to accept the Insight taper joint. Have you ever seem that done? Also, people apparently have used EM2 axles.
I am just trying to get a handle on what parts actually work and what parts I should avoid. If I have to go all custom, so be it, I would just like to know before I go buy parts that I won't be able to use.
Brian, I know we don't know eachother, but I sent you a message on facebook asking some of these questions if you are willing to help clear up some of these issue.
Thanks everyone,
Mike
Old Dec 8, 2014 | 09:02 AM
spAdam's Avatar
Loved
Community Favorite
That's only one on a long list of reasons that it's not really doable. It would be fun if it was though.
Old Dec 19, 2014 | 03:40 PM
jealous1shateric's Avatar
I have a k20 Insight (Gen 1) street car 90% done . Car runs and drives you can email me bolacan413@gmail.com for more information.
CptHMCrunch
May 14, 2013 04:55 PM
Nickboxer7
18
Jul 29, 2007 05:14 PM
slammed_93_hatch
Honda Civic (2006 - 2015)
Oct 12, 2006 04:43 PM
Repodevil
Apr 20, 2006 01:29 PM
IntegraT
Sep 14, 2001 08:16 AM
