B16 alternator fit issues
Old Nov 25, 2014 | 07:42 AM
Mjalaly's Avatar
Default B16 alternator fit issues
Based on this drawing i think the alternator brackets are correct but the upper bolt wont line up.
Cart Contents Honda Parts at HondaPartsDeals.com: Honda Accessory, Honda Car Parts, Honda Auto Parts, Honda Accord Parts
I think the alternator is from a b20 but i am not sure and i cant find a part number. Any way to measure something and double check?
Here is my set up...
Old Dec 5, 2014 | 10:34 AM
Mjalaly's Avatar
Default Re: B16 alternator fit issues
Any thoughts here??
What alternator do i need to fit an OBD1 B16?
Old Dec 12, 2014 | 03:41 AM
Sheela96's Avatar
Find the exact make, model, and year that the motor came out of and go to a parts store. They'll be able to pull it up in their catalog. That's how my lazy *** did it.
Old Dec 12, 2014 | 04:12 AM
Mjalaly's Avatar
I did, but those are obd2. I need and obd1 but I cannot remember the model those came in.
Old Dec 12, 2014 | 04:31 AM
Sheela96's Avatar
I'd say a 00 civic si is a safe bet.
btw, this took about two minutes of searching on google/Wikipedia to find.
Old Dec 12, 2014 | 05:01 AM
ferio-ichi3's Avatar
Ferio Wdm Edition
I had an issue where the the top bracket didnt even fit right. my alt wouldnt sit flush how its supposed to. Instead, it was a little crooked, which chewed belts. Get the right bracket for the motor and itll be fine.
Old Dec 12, 2014 | 06:12 AM
Mjalaly's Avatar
Yeah i know that but i was looking for a more... "I have the same set up and i have this...".
This would be helpful to people later...
Honda Acura Engine Codes Guide
I will try the 95 civic and see if it fits ; /
Old Dec 12, 2014 | 06:20 AM
Sheela96's Avatar
It really doesn't even look like the obd1 B16 was used in North America. Unless you're in Europe or your engine was shipped from overseas, I feel like it might be an OBD2.
Are you sure that is is obd1/is there really any difference on this part of the block?
Edit: I really don't mean to sound condescending. I'm just hesitant for you to throw money at a problem buying parts that don't fit until you find one that does, so I'm trying to get as much information as possible to help us all troubleshoot the situation more effectively.
Old Dec 12, 2014 | 06:38 AM
Mjalaly's Avatar
Yeah its and obd1 because i just finished the wiring harness. It was originally swapped into a 93 civic that's why its an obd1 B16.
i think this one should work... Ultima 15518 - Alternator | O'Reilly Auto Parts
found this thread and that's why i am suspect of the brackets. My b20 alternator should work...if it is a b20 alternator.
https://honda-tech.com/honda-crx-ef-...hread-2986970/
Old Dec 12, 2014 | 12:07 PM
Ferio Wdm Edition
You have to get the right bracket. Even if you use the matching bracket, you may run into clearance issues. When i got my b16 swap, and the top of the bracket would hit the corner of the intake manifold place. Or mounting surface. I looked at the stock gsr one i had on my other block and the supposed b16 one, and they are different. Maybe vtec heads are shorter than non vtec? im sure deck height has something to do with it.
Old Dec 12, 2014 | 04:01 PM
Mjalaly's Avatar
I think i found the issue..
How to tell the difference between D-series & B-series alternators?
The easiest way to tell them apart is to look at the top mounting point on the alternator. The D-series alternators are threaded and B-series alternators are straight through.
I think this is a d series alternator even though i took it off my b20...
Old Dec 12, 2014 | 06:01 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Yes, that photo above shows a "D" series alternator. The "B" series alternator will have the upper bolt hole cast at the 11 o'clock position instead of the 12 o'clock position as pictured.
The first photo has a cast upper alternator bracket and the pic above shows a stamped steel upper alternator bracket... either can be used without a problem.
Here in the US, the alternator that you need would be found in a '94-95 Honda Del Sol VTEC (DOHC 1.6L) or ANY '94-95 Acura Integra LS, RS, GS, or GSR (1797cc or 1834cc).
d1nki
Dec 11, 2006 06:23 PM
hamman-25
Jun 1, 2006 02:25 PM
Old_Honda
Jun 6, 2004 04:40 PM
playAho
13
May 31, 2003 11:57 AM
