J-series pistons in to h22?
Old Nov 25, 2014 | 05:48 AM
KorchEg's Avatar
Default J-series pistons in to h22?
how to do it correctly?
I think I need to use the 4 pistons, one side v-twin engine!
What do you think about this?
Old Nov 25, 2014 | 11:21 AM
kingofbattle909's Avatar
Default Re: J-series pistons in to h22?
What kind of hammer will you be using?
Old Nov 25, 2014 | 11:38 AM
hondamark35's Avatar
Old Nov 25, 2014 | 12:10 PM
bnodle's Avatar
1 halve of a v6 = 3 pistons... you need more better math teachings
Old Nov 25, 2014 | 05:26 PM
KorchEg's Avatar
Great sense of humor !!
I thought people here would guess that H22 has a sleeve which can be increased to 89mm!
The fact that the engine v6, on one side of the piston 3, I also know.
If you do not understand the question, I will try to explain !!
From v6 engine, you can choose 3 of the piston, which will work correctly in the direction of rotation and fit valves
4 must rotate the piston 180 to fit valves, but it will rotate in the opposite direction.
I saw a reverse head H22, there are deploying all 4 pistons 180.
In my case, one piston will not work properly
Old Nov 26, 2014 | 02:02 PM
HiProfile's Avatar
The problem with 89mm & J-series pistons is the 89mm J32 has steel liners. Those pistons will wear away to nothing after a few minutes. Only the J30's had FRM liners, and those pistons are only 86mm.
You can re-sleeve the H22 with iron liners, but then that shoots your whole save a dollar idea all to hell. At that point the K24 pistons would be easier & a better option than taking apart two J32's.
eg_h22
Jun 3, 2009 01:48 PM
Nosboost18
Sep 18, 2008 03:50 PM
margaflow
Jan 27, 2003 07:35 PM
margaflow
Jan 27, 2003 07:17 PM
ratherbewalking
Dec 16, 2002 10:11 AM
