00 civic si b16a - wont rev past 3k RPM until warm
Old Nov 24, 2014 | 07:13 PM
xeejay's Avatar
Default 00 civic si b16a - wont rev past 3k RPM until warm
I have a 00 civic si with a b16a.
My mods are skunk 2 1st gen intake manifold, chipped ecu and intake.
Im having problem with my motor everytime after i turned the motor down and crank it up again. Everytime when i crank it up again after shutting it down, when i rev my motor and it wont pass 3k RPM. It will always go down. For myself to avoid this, i have to wait awhile for it to pass 3k RPM normally.
When it doesn't settle down and i drive, it will lag. For example, when im accelerating, its fine but when i slowly let down gas, it will bogged,lagged, or lets says motor will jump.
note: it already happened before when i put a new ecu. Maybe tomorrow ill switch back to stock and see any changes.
Old Nov 25, 2014 | 01:45 AM
thor33620's Avatar
Default Re: 00 civic si b16a - wont rev past 3k RPM until warm
hi
check the tps and clean the iacv... what's the brand of your tps?
Old Nov 25, 2014 | 07:11 AM
09chaplak's Avatar
Loves Tossing Salad
Yea, do what you said in your note. Switch it with the original ecu and see what changes. I bet the lurching will go away and the lag. What ecu/map are you running?
Old Nov 25, 2014 | 09:15 AM
White_EG1's Avatar
You can't expect a Ecu for a single cam to work on your dohc, is the chip for a obd2 b16? Throwing cels? Switch it for the stock b16 one. Those aren't even enough mods to even get a noticeable gain with a chip lol.
Old Nov 28, 2014 | 10:07 AM
xeejay's Avatar
I took it to the shop and they said its Bc of the Ecu. Bad chipping I guess. They said one part of the chip is chipped and can't be removed.
So I put back on the stock and it's OK now. But time to time it still does it a little.
Old Dec 17, 2014 | 10:14 PM
xeejay's Avatar
http://youtu.be/dhlJQ3_1EB8
OK I switched to stock Ecu but it's still same. I posted a video on YouTube. Please check out out.
Old Dec 18, 2014 | 01:33 AM
HondaPartsHero's Avatar
Technical Hero
You have a check engine light. Pull the code and post it, mostly likely its the root cause of your issue.
Old Dec 18, 2014 | 04:20 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
^^yes.
What is your CEL on for?
Old Dec 22, 2014 | 10:25 AM
xeejay's Avatar
Originally Posted by B serious
^^yes.
Yes I will check it soon.
Old Dec 22, 2014 | 12:41 PM
grumblemarc's Avatar
The Grumpiest
It's been a month. It would have taken you all of 2 minutes of your time and a paper clip.
Old Dec 22, 2014 | 12:57 PM
09chaplak's Avatar
Loves Tossing Salad
And some safety googles!
RJH6
38
Aug 25, 2018 09:41 AM
Johnathan Doe
Feb 26, 2018 10:42 AM
bobbo
Apr 28, 2005 02:29 PM
riceball777
Jun 4, 2003 09:46 AM
skylinecivic
May 13, 2002 01:49 PM
