Prolonged cranking or intermittent no start
Old Nov 24, 2014 | 06:18 PM
1 Phat Cat's Avatar
Default Prolonged cranking or intermittent no start
1993 Honda Civic 4 door Automatic.
Recent drop in temperature into the 30's (may or may not be related)
Cranks for about a minute (Cranking 20 seconds at a time) then starts.
Stopped at a gas station and would not start. Can't hear the fuel pump prime.
Removed the back seat and verified no power to fuel pump at time of no start. Used starting fluid and it started and continued to run until I turned it off 15 minutes later.
Checked all the fuses mentioned in the other posts I have read, 31 13 43 44 and 24 in dash. Removed main relay took it apart and verified solder joints. Reassembled vehicle and now, it will prime after about a 10 second delay with key in run position. Once it starts it runs fine.
Any ideas would be greatly appreciated. On a side note had it not broken down I would have never found this awesome site..
Old Nov 24, 2014 | 06:20 PM
Former User's Avatar
Default Re: Prolonged cranking or intermittent no start
Generally, the problem you describe is caused by a bad ECU.
czachry
May 5, 2018 11:27 AM
HooverHonda13
Jan 7, 2014 07:02 AM
SiRkid
Aug 5, 2009 04:42 PM
91d15bvtec
Jun 28, 2005 01:42 PM
LilMissCrystal81
Nov 19, 2004 11:26 AM
