EJ sedan running rough
Old Nov 23, 2014 | 11:57 AM
MMMGIRL's Avatar
Default EJ sedan running rough
I have a 98 EJ6 that has a D15B swap, Harness and intake have been converted to manual so it has the 2 wire IACV. Whenever you crank the car up it seems to run fine until you go to press the gas, it hesitates extremely bad and you practically have to press it all the way down to even get it to move, it'll start to misfire bad and idle down until it dies. but if you let it sit awhile it'll crank up fine until you press the gas. No CEL, mechanical timing it on even tried a new Dizzy and ecu. Any suggestions
Old Nov 23, 2014 | 12:19 PM
94EG8's Avatar
Seagull Management
Default Re: EJ sedan running rough
Have you tried swapping the MAP and TPS connectors?
Old Nov 23, 2014 | 02:44 PM
92ehatch's Avatar
I would verify they are in the correct place rather than just swapping them
charlesoliver
Oct 19, 2014 12:34 PM
Murk 'EM
Jul 16, 2009 08:48 PM
LSegHatchy
Jul 18, 2008 11:41 AM
vtecsi00
Mar 5, 2008 12:35 PM
NowABeliever
Sep 24, 2007 04:12 AM
