Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2006 accord ex front suspension torque specs
Old Nov 21, 2014 | 09:55 PM
cmb7684's Avatar
Default 2006 accord ex front suspension torque specs
I have a 2006 Honda Accord EX 4 door Sedan 4cyl motor automatic trans 155,000 miles. I replaced the front suspension parts: struts, upper and lower control arms, lower ball joint, cv joint axles both sides, stabilizer bar end links, outside tie rod ends and new bearings.
I just want to make sure I have everything tightened right to avoid any issues. Can anyone give me the torque specs for the front end or more specifically the specs for the bolts at the top of the strut tower, the lower fork assembly the strut goes into, the upper control arm bolts, lower control arm bolts, the stabilizer end links, the outside tie rod ends and the axle bolts?
Old Nov 23, 2014 | 06:29 AM
Lost Again's Avatar
Default Re: 2006 accord ex front suspension torque specs
That is a long list......for ~$22 you can buy a service manual for your car and it will have almost everything you will ever need.
automanualsource "dot" com
Some parts stores might print off all of what you are looking for?
Matt Isaacks
May 14, 2016 12:20 PM
drcain
Sep 10, 2007 03:41 PM
Tim2179
Aug 1, 2006 05:39 PM
