92 Civic/B16 swap - 2K rpm cold idle, low warm idle and cuts off
Car is a 92 Civic hatch - obd1 - b16 - head work and cams
Car ran fine till one day starting it up. Idled around 2k as it warmed up it idles down and cuts off within 2-3 minutes. Car has a new oem idle air control, coolant bled proper. Car is tuned on crome and made 200 whp. car has a new dist. as well. car has no 02 sensor - deleted. ran fine up till this point and was tuned without one (wideband in tailpipe on dyno).
suggestions?
suggestions?
So you started it cold.idled high then slowly worked down and shut off?
Or it started high then just shut down?
Did it bounce arounda bit first? Will it run at all now?
Check all vacuum hoses pcv fitvs and timing is always good to check
Might be good to check the tps as well
Looking at a tps sensor. Owner found a thread related to it.....I will also give him the suggestions about a vac leak. Thanks!
Idles normal cold idle, then as it warms up it idles lower and lower till then it cuts off.
vtec_yosh
Nov 29, 2003 09:25 PM
