AT with too much fluid.
Old Nov 21, 2014 | 12:09 PM
Das Cenouras's Avatar
Default AT with too much fluid.
What will happen if my transmission has too much transmission fluid ? i have a leak some where.. i took out some of the solenoids in the transmission and didnt replace the gaskets.. also .. i think i putted too much fluid in the transmission.. and know i dont know if that is normal.. or its the gaskets needing to be replaced.
Does the transmission have an escape mechanism for the fluid ?
Honda civic 2000 AT engine D16y8 1599cc
Old Nov 21, 2014 | 12:22 PM
tony_2018's Avatar
Fish Twig
Default Re: AT with too much fluid.
No you should not have too much fluid, these autos are picky.
Old Nov 21, 2014 | 02:01 PM
So.. i really should replace the gaskets in the solenoids.. right ?
Strange thing.. is.. its leaks a little.. but i check the fluid levels everyday and its always above the max limit. i think i puted 2 bottles 2 much of fluid.
Old Nov 21, 2014 | 06:14 PM
92ehatch's Avatar
replace solenoid gaskets drain excess fluid be done
Old Nov 22, 2014 | 03:11 AM
Former User's Avatar
Car, engine, transmission information is required. Edit your first post to add this information.
Canucksfan101
Feb 2, 2015 10:05 AM
Extreez
Oct 16, 2006 10:18 AM
Thunder Cat
Dec 9, 2005 03:39 AM
CivicRaping
Mar 20, 2005 06:49 AM
