Replacing Oil Pan on 2006 Pilot
My dad is needing to replace the pan on his 2006 Pilot. Just curious if anyone here has swapped one out, and if there are any gotchas to look for. A quick search of the archives didn't turn anything up.
Also, in searching for parts, I haven't seen any part numbers for a gasket. If you order a 11200-RDJ-A00, does that include a gasket and drain plug, or is it just the bare oil pan?
After an oil pan leak on my 2006 Honda Pilot ELX Jiffy Lube told us not to bother with replacing it. They told us that honda makes the cheapest oil pans but that the replacement was expensive. In my case thankfully it was just the cap on the pan that was leaking.
trooper0641
14
Oct 11, 2005 07:11 PM
