Acura TSX Acura TSX Sports Sedan. USDM TSX and Euro/UK/JDM Accord.
Ignition Coil and Tune Up Cost
Old Nov 20, 2014 | 07:30 PM
ncgirl's Avatar
Icon6 Ignition Coil and Tune Up Cost
Are these prices reasonable or a rip off? ACURA TSX 2005 - 170k miles, last tune up-2011,
Diagnostic $50
(Cylinder 1 misfire)
Engine Analysis
Spark Plug Replacement 4 @ $24.99 $99.96
(Brand unknown)
Removal of spark plugs $69
Ignition Coil (Brand unknown) $146.99
Fuel System Cleaning
Cleaner $20.00
Labor $27.50
Parts- $266.94
Labor $146.49
tax- $ 18.62
Total - $432.05
Old Nov 22, 2014 | 12:50 AM
siblues's Avatar
Default Re: Ignition Coil and Tune Up Cost
They are trying to rip you off.The coil can be bought online from an Acura dealer for 80 bucks the spark plugs maybe 40-50 bucks and the 69 bucks for removal of spark plugs is just crazy.
Old Dec 9, 2014 | 10:25 AM
Mattb16teg's Avatar
Community Builder
Community Influencer
That is ridiculous but is what you expect from a dealer. You can do this all yourself. I got OEM Ngk plugs from Advance for like $30 with a coupon.
Old Dec 9, 2014 | 04:24 PM
WanaBeFaster's Avatar
Those can't be dealership prices. Spark plugs for tsx is 1 hour labor so usually would be around 100 labor plus parts lol. Whatever you do, do not buy a fuel system cleaner. It's a rip off no matter how much it costs.
Old Dec 24, 2014 | 09:19 AM
goforbroke's Avatar
MEAT PATTY
x2
I would let them run the diagnostic on the engine misfire code unless they already figured it out. Chasing a misfire code can be a PIA I'm currently also throwing a misfire on cylinder number 1.
If they are changing random parts to figure out the misfire, I would go some where else.
Old Dec 30, 2014 | 10:26 AM
Mattb16teg's Avatar
Community Builder
Originally Posted by goforbroke
x2
Check injectors and coil packs already?
Old Dec 31, 2014 | 02:50 PM
goforbroke's Avatar
MEAT PATTY
Checked the following already:
Spark plugs
Ignition coils
Fuel injectors
Fuel injector harness
Ignition coil harness
Compression test
Vacuum leaks
Valve adjustment
As you can see I'm having a blast with this.
I'm going to check my fuel pressure next, hopefully that will tell me something.
I have Flashpro on my car but I haven't messed around with software much yet but I'm sure my problem is within the software Ect..map valve, fuel trim etc....lol
Old Jan 2, 2015 | 06:06 AM
Mattb16teg's Avatar
Community Builder
Spark plugs
Ignition coils
Fuel injectors
Compression test
Vacuum leaks
Valve adjustment
damn, I have an issue years back in my CL, where the injector was slowly dying and working 50% time, giving me a miss fire when it wasn't of course. Took me forever to run it down because most of the time when it would work and showed no signs of being the issue. Finally switched injectors around and noticed the miss fire changed Cylinders. HUR DUR moment for sure.
Yea could be something in the software. Too bad you can't just slap another ECU in there to test.
Old Jan 2, 2015 | 06:11 AM
ferio-ichi3's Avatar
Ferio Wdm Edition
70 bucks to take out the old spark plugs? That should have been the first clue as to a rip off lol. As someone mentioned, everything on that list can be changed out by yourself. No fuel system cleaner though.
Old Apr 1, 2015 | 11:33 AM
tamboo's Avatar
10 Year Member
always ask for your old parts, sounds like you might be able to test and re-use some of them lol.
most of that stuff is pretty easy to do, just watch some youtube.
https://www.youtube.com/results?sear...tsx+spark+plug
Aesthetic Gains
Sep 21, 2012 04:07 PM
fastlimegreencivic
Classic Hondas
May 5, 2010 05:30 PM
