95 Accord. (Batt or Alt)
Old Nov 20, 2014 | 10:21 AM
youngkidd's Avatar
Default 95 Accord. (Batt or Alt)
I'm hoping someone can drop some knowledge on me on what's happening.
It's a 95 Honda Accord 2.2 engine. Issues is that it seems to have a low charge. I put a new battery to see what would happen and its still the same result. NOTE: car still turns on and stays on even after diconnecting the battery while car engine running.
Old Nov 20, 2014 | 06:13 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 95 Accord. (Batt or Alt)
Clean the battery tray.
Clean battery.
Verify battery connections are clean and tight.
Verify cables are not degraded, overheated, corroded.
Verify cable connections to engine and fuse box are clean and tight.
Verify main ground attachment to transmission, and jumper on engine mount are installed correctly, as well as clean and tight.
Verify battery is can hold a full charge of 12.6V.
Verify electrical system is properly charging when engine is idling with no accessories on charging voltage will be between 13.9-15.5Volts.
Turn blower fan on, voltage should not be lower than 13.5Volts.
Old Dec 8, 2014 | 01:11 PM
Suma's Avatar
Terminal corrosion is big on these cars.
wcsinx
Jan 16, 2019 06:12 PM
Ryan Hammond
Oct 2, 2014 12:48 AM
justmeandher
19
Mar 12, 2014 05:21 PM
92 CIVIC HATCH VX
Feb 22, 2009 10:56 PM
skiracer8148
Jan 4, 2006 09:00 AM
