aftermarket rta bushings worth?
Old Nov 18, 2014 | 11:24 PM
Ef4doorwagon's Avatar
Default aftermarket rta bushings worth?
Are aftermarket RTA bushings bad to get? I was reading through suggestions and someone said using polyurethane bushings as replacement for this is bad, that you should try and get oem. Honda quoted me at almost 80$ a bushing... And I need 2 for my wagon and 2 for my sedan... So I can't spend 320$ on 4 bushings... I was looking at eBay http://m.ebay.com/itm/130574043991?nav=SEARCH^ has anyone bought these? I know cheap isn't the way to go, but I just can't justify in paying hundreds for small rubber pieces.
Old Nov 19, 2014 | 03:43 AM
James89DX's Avatar
Default Re: aftermarket rta bushings worth?
I have Dorman units on mine. No complaints. They come with a mark already scribed on them at the exact depth they need to be pressed in
Old Nov 19, 2014 | 03:56 AM
KevinEF7's Avatar
I also have bought the Dorman replacements off rockauto for about $25 each. I would not buy cheap chinese off ebay
Cant go wrong with oem honda pieces, even if they make you pay for it, they lasted 20 years... chinese rubber will have you fretting in less than a few
Old Nov 19, 2014 | 05:40 AM
M3THTICAL(EF)'s Avatar
Yeah i got the Moog units from rockauto. I think i seen some selling for $60 for a pair of oem bushings.
Old Nov 19, 2014 | 08:03 AM
Dorman ones are about 25 each. I won't use rock auto but I see some on jegs
Old Nov 19, 2014 | 10:36 AM
Tyson's Avatar
OEM is $32 for a bushing.
52385-S21-003 - Genuine Honda RR Trailing Arm Bush
Old Nov 19, 2014 | 12:12 PM
94eg!'s Avatar
#1 Super Guy
Loved
Originally Posted by 94eg!
There are 3 part numbers that fit Integras.
Civic/Integra from 2000: 52385-sr3-000
CRV from 2000: 52385-sr3-003
Revised Civic/Integra from 2002: 52385-S21-003 https://docs.google.com/viewer?a=v&q...BHFzgGAK7oCnoA
The TSB's go back & forth recommending which part. The 2006 version started recommending the original part number again for some reason. https://docs.google.com/viewer?a=v&q...PbDUwHBHXyc77A So who really knows which one is better? Nobody.
Currently the SR3-000 is the most updated one, but it's also the most expensive at $52 each.
You can get the CRV version SR3-003 ($28 ea) for even less than the old updated S21-003 ($32 ea). Nobody is sure the exact difference in the CRV bushing, but I do know they fit perfectly into my 89 CRX.
To install, I just used a 2lb brass hammer from harbor freight. Old ones knock out the front, new ones knock in the way the old ones came out. Just be sure to set the rotation & depth correctly.
Tenzo
Suspension & Brakes
13
Feb 1, 2015 04:42 AM
91akira
Jul 4, 2013 02:31 PM
JDM215
Suspension & Brakes
Nov 3, 2010 10:56 PM
theineffable
Honda Civic (2001 - 2005)
Oct 12, 2010 04:12 PM
bkowa092
11
Sep 30, 2010 06:21 PM
