Delsol tune up,what first?
Old Nov 17, 2014 | 05:56 PM
teamleader's Avatar
Default Delsol tune up,what first?
just bought a 93 delsol si with a 1.6 vtec. Car sat for 5 years. Got it running now and need advice on what to do first.i was thinking a tune up kit ,timing belt and oil change.where is the best place online to buy stuff? Car has 176000 miles on it.
Old Nov 17, 2014 | 06:05 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Delsol tune up,what first?
It would help to know your general geographical location.
What works for someone in the states may not be as good for someone is Canada or Mexico.
Old Nov 17, 2014 | 06:07 PM
teamleader's Avatar
Central florida
Old Nov 17, 2014 | 06:45 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
If you'd like OEM parts, I'd recommend Honda Parts OEM 30% Off | No Tax!! Outside California | Honda Dealer Parts
Rockauto.com if you want inexpensive parts.
eH.
Old Nov 17, 2014 | 07:13 PM
tony_2018's Avatar
Fish Twig
Owners manual will tell you what needs to be done at certain intervals. Also if the prevous owner didn't provide any receipts for previous maintenance than you have the whole shebang to do.
Old Nov 17, 2014 | 07:36 PM
teamleader's Avatar
I figured oil change, spark plugs,spark plug cables,rotor,distributor,timing belt,flush radiator and transmission .thought I could find a kit?
Old Nov 17, 2014 | 08:39 PM
EsotericImage's Avatar
Retired Moderator
stick with OEM parts and youll be fine.. especially with the rotor and cap.
I would be more worried about the gas sitting in it for years. I would dis connect the line at the rail and let the pump do its thing. Id use that old gas in a lawnmower or something needing 2 cycle oil..
Old Nov 18, 2014 | 02:17 AM
teamleader's Avatar
I had to pull the tank off and clean it out with acid.the tank was still full, but had turned a dark brown ,almost like a varnish/tar mix., fuel pump and float were no good,had to replace both of them.
Old Nov 18, 2014 | 10:37 AM
Former User's Avatar
Replace the engine oil and transmission fluid.
Old Nov 18, 2014 | 06:42 PM
belairbrian's Avatar
If the car has been sitting for 5 years, i'd start with the brakes. The seals have been sitting turning hard, and brake fluid absorbs moisture. No fun getting it running only to find out it doesn't stop.
Good chance the valve cover, pan cover and distributor seals are hard and leaking.
The other things you're considering are good ideas. timing Belt, water pump, while doing all that the front crank oil seal and cam seal.
A search of the net should find electronic copies of the FSM.
Old Nov 19, 2014 | 05:01 AM
Matyikaaa90's Avatar
Originally Posted by teamleader
...Car has 17600 miles on it.
WUT?! 17,600 miles. Damn, that's like nothing.
Old Nov 19, 2014 | 12:10 PM
teamleader's Avatar
Sorry that was a typo,it 176000 I believe.
Old Nov 20, 2014 | 10:39 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Nobody pointed you to this yet? https://honda-tech.com/honda-civic-d...civic-3114911/
Tu dois lire cela; c'est quasiment obligatoire.
Strange World
Jan 7, 2013 04:59 PM
csckwade
59
Jan 4, 2013 04:42 AM
STREETFIGHTER50
May 10, 2008 10:26 AM
Convert
Jul 31, 2007 06:15 AM
alpha
Nov 13, 2003 04:50 PM
