nos plate kit??
Old Nov 1, 2002 | 09:41 PM
prjctCIVIC's Avatar
Default nos plate kit??
planning to get the nos plate kit, anyone using this kit???
Old Nov 1, 2002 | 09:45 PM
typeSwarrior's Avatar
Default Re: nos plate kit?? (prjctCIVIC)
No, but that's what I plan on getting once I get some cash flow again The ignition is underway, very soon. What were you wanting to know about it? I've read some on it and I know it's applicable for B18 (GSR) and H22 motors because the plate is specially designed for the intake manifolds. Not quite like a DP kit, but similar I guess you'd say. Depending on how built your motor is, that particular kit is adjustable 75-200 shot. That's a in my book
[Modified by typeSwarrior, 12:47 AM 11/2/2002]
Old Nov 1, 2002 | 10:02 PM
prjctCIVIC's Avatar
Default Re: nos plate kit?? (typeSwarrior)
planning to use it on a stock 94 jdm h22....but in the NOS catalog is lists only for the h22a4's?? so wondering if it is compatible with the older h22 motors??? so its not like a Direct port system??
Old Nov 2, 2002 | 08:26 AM
fastludeh22's Avatar
ya it says that but i was told the butterflies are the same for h22a1,h22a4,h23a1...someone also said the gsr ones are the same also? but i was wondering if they restrict airflow enough to lose hp? what about on a turbo motor?
Old Nov 2, 2002 | 09:50 AM
laughinxxx's Avatar
New User
Default Re: nos plate kit?? (fastludeh22)
The plate kit isn't coming out anytime soon unless you you have a direct hook up to Holley. The NOzles kit did come out though along with the import adapter for the injectors. Of course it is $1k+, but it's the easiest install that you they have.
Old Nov 2, 2002 | 02:58 PM
Default Re: nos plate kit?? (laughinXXX)
Well that's why I said that, I have a direct hook up
-Midnight-
Jun 12, 2003 06:14 PM
McFly
Oct 16, 2002 02:06 PM
zdr262
Jan 10, 2002 05:28 AM
redteg1
Dec 24, 2001 11:20 AM
