1993 Del Sol - Manual Rack and Pinion Replacement
I've begun the process of replacing the manual rack and pinion on my Sol and have run into a brick wall. I got up to the point where the rack is loose but I can't for the life of me get it out.
I've already dropped the exhaust and that helped a bit but I still need more clearance. I've read that undoing the shift linkage can help (I already followed the link in the FAQ about getting the spring pin out with a c clamp).
Is this the only thing that I can loosen to help make space? Any other tips for removing it? Thank you.
have you disconnected it from the steering linkage? if you have try removing the tie rod ends that should give you more movement.
Unfortunately I don't have an FSM, but I will list in detail the steps I have taken so far.
Jacked up the car and put it in stands. Removed both front tires.
Loosened the outer tie rods a bit. Removed cotter pins and removed castle nuts. I used a tie rod seperator to pull the tie rod out of the steering knuckle.
Removed the outer tie rods (have replacements on hand). I then climbed into the car and pulled open the steering column and undid the 2 bolts to seperate the rack and pinion.
Climbed under the car and removed the 2 spring bolt things on the exhaust and lowered it down to make room.
Undid the 4 bolts holding the rack and pinion. It is loose now but still doesn't clear.
Hmm I will definitely look into it now. I was previously working a job that barely left me any money and so it was a bit pricey from that website. I finally got a job as a teacher so the money won't be as tight anymore. Thank you for posting those Ron
Well I got the rack out today with little problem after following the FSM. I had ordered the new rack from rockauto. The last thing on my mind was if it was going to fit properly but when I compared the two I noticed that the rubber piece that gets bolted on the passengers side was not lined up. I put the two parts side by side and there was a slight difference.
The rubber part was too far to the passengers side and the holes would not line up. I tried moving the rubber part over and I had no luck. The part I ordered was an aae 4223n manual rack and pinion. The one I received has a stamp that says aae 10y13. I tried searching google but that part number doesn't seem to exist and rockauto doesn't carry it either.
Has anyone run into this problem before? I'm going to call rockauto tomorrow and see what happened as well.
It looks like the wrong passenger side dust boot may have been installed on the original rack and it was also installed in the wrong the location. The passenger boot on the Rock Auto rack makes more sense to me.
But are you saying that the two bolt holes near the valve body of the Rock Auto rack also do not align on your car?
Yes. The original rack fits perfectly. The c shaped metal piece that has two holes in it for bolts fits in a rubber piece on the passenger side. On the original it fits in the right spot and the holes line up. On the new rack if I put it on the rubber piece the wholes do not line up. It has to be placed almost halfway off the rubber piece to make it fit.
The two bolts on the drivers side fit perfectly. Its the other two on the passenger side that do not line up.
I may be able to, but I haven't tried it. The thing that was off putting is that there is an actual difference in the lengths of the racks. It is slight but it is definitely there. I'm not sure if that is important but I thought it was.
Switching the cushion between the two seems feasible but I would have to take the boot off and put a zip tie on it?
I'm not sure the slight length difference is a big concern given that the tie rods allow the length to be adjusted during the alignment.
The rack would probably install fine if you transfer the rubber cushion and bracket from the original rack.
The odd thing to me is the passenger dust boot and its unusual placement on the original rack. That doesn't look right to me.
Well maybe its just because it is so broken? Well I will try and transfer the cushion tomorrow and see if that does anything. It doesn't seem like the cushion needs to be particularly secure since it gets bolted down. I might try and just cut it loose so that it can slide freely from side to side so that I can align it with the holes.
While you are here Ron, is there a trick to getting the rack aligned perfectly so that you aren't even a single tooth off? I saw some people mention to count the number of spins it does when you go from one side to the other and divide by two but it seemed a bit inaccurate and I may be off by a tooth. Is there a more precise method?
DelSolMike
Oct 19, 2013 06:13 PM
delsol8017
Dec 9, 2008 05:21 AM
Spade
23
Mar 20, 2002 09:02 PM
