Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Starter?
Old Nov 16, 2014 | 02:57 AM
nizle144's Avatar
Default Starter?
So I have a v6 auto car and it has got to where it won't start from time to time. Fuel pump is priming, battery is good, but when I turn the key to start there's nothing. After I tap the starter a couple times and turn the key it will click one time then the next time I turn the key it will start. Any opinions?
Old Nov 21, 2014 | 10:35 PM
Lucky Flow's Avatar
Default Re: Starter?
Get it replaced asap, it's going to die soon and your trick won't work.
If you don't mind dirty fingers, it should only take about 2/3 hours to change out.
You'll need a starter, and a upper intake manifold gasket. Yes you have to remove the intake manifold.
Old Nov 23, 2014 | 06:38 AM
Lost Again's Avatar
The OP didn't give info on the "year/gen" but did state that they have a v6. Didn't look at the 8th gen accords but the 7th gen v6 starter replacement is totally different than on 4cyl.
Old Nov 24, 2014 | 12:25 PM
nizle144's Avatar
My fault guys. It was an 07 V6. It was the starter. I went 2 sundays ago and got a new one from oriellys and it took me about a hour to change. 6 days later that one went out sitting it radio shack parking lot. It was warrantied for free and took me about 30 min to swap that one. Not real sure what made it fail but while it was in the car you could hear it pooping out but not spinning. When I returned it to oriellys they hooked it up and it would spin but not pop out.
Old Nov 24, 2014 | 12:26 PM
nizle144's Avatar
Sorry didnt specify the year but on an 07 V6 you do not need an intake manifold gasket
PatrickGSR94
Jan 13, 2024 05:15 AM
Derrick Carr
Honda CR-V & Element
Jan 24, 2018 06:30 AM
Book1483
Jan 10, 2018 05:17 PM
itr590
Dec 21, 2010 08:16 AM
DAYUIZ
Jan 20, 2004 03:03 PM
