Mystery B Motor I bought for $50 lots of Pics
Old Nov 11, 2014 | 08:24 PM
ChrisCoupe1's Avatar
Default Mystery B Motor I bought for $50 lots of Pics
Ok so I went out an got a full B16A short block from Craigslist that had apparently spun a bearing....well First off the guy I bought it from (he is a old Honda dealer Tech) said he bought a civic chassis from some kid who couldnt fix it. It apparently had a bad knock from a "spun" bearing. Anyways it sat for years until he decided to clear out his old stuff. He noted that he thought it was odd a GSR P72 head would be swapped onto a B16A...so did I since I saw it had P72 pistons....I got P72 mixed up with P73 in my head an said hey someone put ITR pistons into it.....oops my bad lol.
Anyways tonight during our tear down of the short block I noticed hey thats weird they put a P72 oil pan on it..ok...then hey they put a Crank Girdle on it...weird but ok....then WTF P72 stamped rods...thats impossible to fit into a B16A an not have the pistons pop out the top right?
Then upon closer inspection of the Block I found P72 markings on it and after really looking at the serial number plate it looks as if someone cut one off a B16 and welded it over a B18C for god knows why.... anyways tell me what you guys think. Also I measured the Height of the Sleeve and it was right about 5.45 inches which is 138.4MM
The reason for the "rod knock/spun bearing"
Probably cant fix that
Old Nov 11, 2014 | 08:56 PM
Default Re: Mystery B Motor I bought for $50 lots of Pics
what was up with the B20? Haha I just wanted the block an crank but with this I might change my plans if I Can salvage it
Old Nov 12, 2014 | 08:28 AM
Anyone have any idea if the damage to the sleeves/block can be welded/repaired for it to still be usable or are the sleeves scrap now and I'd be better off shelving this until until it can get sleeved?
Old Nov 13, 2014 | 11:57 AM
bspeed's Avatar
You can get it sleeved and the bolt cut out by EDM. You could also just get a good block for less. A machine shop might buy it off your for the crank.
Old Nov 13, 2014 | 12:23 PM
LTCxD2B's Avatar
Can't tell from ur pic but if it's just the bottom corner it's fine .... Just like notching the single cams for bigger rods ... And people do this to beat inspection at the track for displacement ..
Old Nov 13, 2014 | 02:36 PM
Yeah that's what me an my buddy thought when we started to pull it apart but the picture doesn't quite show how bad one is...looks like it could have gotten to the water jacket and the cylinder wall is gotten a rod width size chunk taken out of it. I'd really like for it to be savable just don't think it is.
Man some people just cant play by the rules huh lol
Getting it sleeved is the last option...if I can get money back out of this thing I'd be pretty damn happy.
Old Nov 17, 2014 | 01:22 AM
m4xwellmurd3r's Avatar
A plate welded over wont pass tech for displacement just cause how shady it looks.
More like someone stole it.
Old Nov 17, 2014 | 08:09 PM
Yeah that's one possibility... but why would someone paint it too? notice its flaking off qyite a bit around the plate region.
Old Nov 18, 2014 | 03:12 AM
LTCxD2B's Avatar
More cover up for the sketchiness lol
Old Nov 19, 2014 | 01:39 PM
Nice well now I get to see if boring this thing out to 82mm will make the sleeves salvageable so their wont be any interference with the piston rings....If so then onto attempt fixing that sleeve:water jacket chunk missing.
Old Nov 20, 2014 | 03:22 AM
turbodcxbro's Avatar
I'd cut your losses and find another block bud, they aren't that hard to find. going 82mm on stock sleeves is risky especially if they have prior damage. Either get this one fully sleeved or pick up another and start your build.
Old Nov 20, 2014 | 05:55 AM
unknown4now's Avatar
x2 !!!!
Old Nov 22, 2014 | 06:32 PM
Originally Posted by unknown4now
x2 !!!!
hah yeah I'll get to that bridge after I complete my B20 build.
Old Nov 25, 2014 | 07:34 AM
No I'm Building a B20V for my DD car,
I picked this block up cause it was a descent deal and figured it would be smart to have a spare block just in case.....$50 for a full short block isn't a bad deal any way you slice it. If You take a close look at the pic down the sleeve you can see where its damaged from the bent rod.....depending on the how high that damage goes I think I might be able to salvage the sleeves by getting over sized pistons(82mm) and measure for clearance of the oil control ring when at BDC.....if the damage to the sleeves doesn't go that high then all thats left to do is make sure that the sleeve to water jacket isnt damaged...if thats the case this thing will be good for a rebuild.
at least thats my thinking.....worst case scenario I sell the sensors and Crank to break even or get a little extra money back out of it then scrap the block or hold onto it to eventually get sleeves installed.
Old Nov 25, 2014 | 10:23 AM
boostedeg138's Avatar
bump
Old Nov 25, 2014 | 06:51 PM
NoRush's Avatar
Worse comes to worse you can make a sweet coffee table out of it.
Old Nov 25, 2014 | 07:55 PM
HAHAHA the thought did cross my mind lol
Old Nov 26, 2014 | 03:01 PM
tony_2018's Avatar
Fish Twig
It looks like he notch the cylinder walls to accept the rods and crank.
Old Nov 26, 2014 | 07:36 PM
Yeah thats what we thought at first but its only on 2 cylinders the ones with those bent *** rods....apparently it was driven for 60-70 miles with those like that.
longshot
11
Jan 19, 2009 06:07 PM
ahki
Jan 10, 2005 03:55 PM
2dregcivic757
Apr 20, 2003 11:30 AM
Del
Jan 2, 2003 02:33 AM
B_CRUZ!
Nov 14, 2001 07:04 AM
