12V plug blowing fuses
Old Nov 11, 2014 | 07:21 PM
Exodeon's Avatar
Icon2 12V plug blowing fuses
Bought a '93 Civic DX with a D16Y7 swapped in for $800 with only minor issues. Current issue I'm tackling is the 12V plug. It was rusted out so I bought a new one and installed it. Now it's blowing fuses left and right. Left it uninstalled for now so I can use my new head unit (it had a dead OEM unit). My phone could really use a good charger so what could be going wrong? Can provide pics if necessary.
Old Nov 11, 2014 | 07:22 PM
Former User's Avatar
Default Re: 12V plug blowing fuses
Post pictures of the plug, its wires, and the fuse that is blowing in the box.
Old Nov 11, 2014 | 07:42 PM
Exodeon's Avatar
https://www.dropbox.com/s/5nyohmv9k3...35.09.jpg?dl=0
https://www.dropbox.com/s/ub95d9iw11...34.43.jpg?dl=0
https://www.dropbox.com/s/g9ltvjtpub...31.39.jpg?dl=0
I go out and get a pic of the fusebox. Temporarily using a higher rated fuse and will be getting the proper one tomorrow. It blows only when the 12V is installed and immediately when I turn the key to accessory.
Old Nov 11, 2014 | 07:50 PM
Exodeon's Avatar
https://www.dropbox.com/s/lzixpl7v15...46.32.jpg?dl=0
It's the yellow 20 fuse. Ran out of 15s because of this problem.
Old Nov 11, 2014 | 08:06 PM
crazyhouse2011's Avatar
sounds like a short. OP I would verify that the wires running to the plug are not touching each other, also, make sure any connections or joined wires have heat shrink or insulated connectors around them.
Old Nov 11, 2014 | 08:09 PM
The hot wire for the cigarette lighter should be Yel/Red, which is missing in your picture. Please clarify.
In addition, you have spliced a white plug to the modified wires. This extra plug has a Wht/Blu wire, which looks burned. This burning suggests the location of the short that is blowing fuse 23.
Old Nov 11, 2014 | 08:15 PM
Exodeon's Avatar
I was figuring that is the issue. This is how the harness looked when I first opened it up. I thought the wire was burned but it just wiped off with my finger. I have a cheap multimeter I got from Harbor Freight. What should I do to verify if all the wires are functioning properly?
Old Nov 11, 2014 | 08:19 PM
Do you use or plan to use both the white plug and the cigarette lighter plug?
Not sure because I can't see both ends of the Red/Blk and Blk wires, but the plugs appear to be connected in series, which is unusual. Can you post additional pictures that make the wires more visible?
Old Nov 11, 2014 | 08:20 PM
slomofo's Avatar
GDD Member
Disconnect all the wires to that 12v outlet, put the fuse back in, then probe wires with a test light to find which one is getting power. I suspect you have power/ground mixed up in your connection.
Old Nov 11, 2014 | 08:30 PM
Exodeon's Avatar
The plug connects to the main dash harness. Red/black goes to that bulb that goes into the ashtray.
https://www.dropbox.com/s/1y2pp1ksvd...26.52.jpg?dl=0
Old Nov 11, 2014 | 08:43 PM
I suspect that whole setup was custom rigged by the previous owner.
If you install a new fuse into the 23 slot with that set up in your picture left unplugged, does fuse 23 no longer blow?
Also, can you post a picture of the male plug that connects to the plug in the setup and also show its wire colors?
Old Nov 11, 2014 | 08:47 PM
Exodeon's Avatar
This does confuse me. See the first pic? Red/yellow wire plugs into white/blue on my small harness. I am getting a light up from the r/y wire but the black and b/r one give nothing. Accidentally let the black connector touch the white/blue connector and it blew the fuse again. I can't let the white/blue touch anything metal while the car is on or it kills the fuse.
https://www.dropbox.com/sc/qub05cun6mxoxom/AACJm3tVuathgNPSRA5ktGn-a
https://www.dropbox.com/sc/caqmb2dtvi6r00a/AABqA2k_kCOLJ0_LTuZ1kt4Na
Old Nov 11, 2014 | 08:50 PM
Exodeon's Avatar
Will the two pics in my previous post do?
Old Nov 11, 2014 | 08:52 PM
Yes^
Okay. I see the problem. The previous owner rigged the added light to share ground with the cigarette lighter. That won't work.
Spliced into the Blk wire between the bulb and white plug is a metal female connector that was connected to the cigarette lighter. Remove that metal female connector. The splice/shrink wrap the Blk wire at that point. Save the removed connector.
Old Nov 11, 2014 | 08:54 PM
Exodeon's Avatar
Yes^
Okay. I see the problem. The previous owner rigged the added light to share ground with the cigarette lighter. That's won't work.
I have no need for that light. Is it as simple as just removing that connection? What is this supposed to look like out of the factory?
Old Nov 11, 2014 | 08:59 PM
See added text in my previous post. Keep the light as it probably was illuminating something in a different location originally. Try to find its original home.
Solder the removed metal female connector to a fresh separate Blk ground. Plug the metal female connector into its original male connector on the cigarette lighter. Either find a screw in the metal frame under the dash to ground the other end of the Blk wire or drill a hole in the metal frame to add a screw to affix the Blk wire.
Now the light and cigarette lighter should both work.
Old Nov 11, 2014 | 09:14 PM
Exodeon's Avatar
I need a bit more slack for the ground connector I removed. Can I use the illumination orange wire from my head unit? It has zero use in this car. I can just cut that off and connect it from a screw to the ground wire.
Old Nov 11, 2014 | 09:21 PM
1) What do you want to use the orange wire for? Does the orange wire connect to a Red/Blk wire in the Civic wire harness? If so, that's a hot wire.
2) It looks like the bulb in your picture is actually stock for the Civic cigarette lighter. Does it work? If so, does it dim and brighten with the dimmer switch or is it constant full bright?
Old Nov 11, 2014 | 09:24 PM
Exodeon's Avatar
2) It looks like the bulb in you picture is stock for the Civic cigarette lighter. Does it work? If so, does it dim and brighten with the dimmer switch or is it constant full bright?
I've never seen it turn on to be honest. And the orange wire connects to nothing. It's for the head unit illumination that my car doesn't have. I'm about to screw in the new ground connector now.
Old Nov 11, 2014 | 09:26 PM
So it's just an extra piece of wire? If so, that's fine.
Old Nov 11, 2014 | 09:29 PM
Did you do this^ important test?
Old Nov 11, 2014 | 09:33 PM
Exodeon's Avatar
We have light! It's constant bright, no dimming.
https://www.dropbox.com/sc/wtgqh4a6dbab2kd/AABRApmgECp7qdQqNoKGN50ga
And here is where I placed the new ground. Haven't plugged in the 12V plug yet. Hope it doesn't blow another fuse.
https://www.dropbox.com/sc/xokhvhjiwri3nc0/AACvvFND_Yq4uYSBVdBr-wIka
Old Nov 11, 2014 | 09:34 PM
Exodeon's Avatar
Indeed I did. My stereo is on the same fuse and works fine without the 12V plugged in.
Old Nov 11, 2014 | 09:41 PM
Not sure but I may see another potential issue. See diagram below. In post #6, the Wht/Blu wire may not be connected correctly. Shouldn't it attach to the nearest male prong below?
The orange ground wire should attach to the lower side prong where the Blk wire was connected.
Old Nov 11, 2014 | 10:00 PM
Exodeon's Avatar
I see another potential issue. In post #6, the Wht/Blu wire may not be connected correctly. Shouldn't it attach to the nearest male prong below. The orange ground wire should attach to the lower side prong where the Blk wire was connected.
It's the only place it can fit, as the other places are too large. The grounds are officially separated. Fuse still blew. Unplugged the white/blue and installed a new fuse and it's functional again.
