B16A2 build
Old Nov 11, 2014 | 12:07 PM
jubile7's Avatar
Default B16A2 build
Hey guys, been lurking around for a while now, finally decided to join.
I actually own a Subaru but decided I want to have a cheap Rallycross build....like B16A2 in a CRX or something to that effect.
I've been doing a lot of research but I still wanted to get some fresh opinions from the humble members of this community
I've worked on cars for years now, but I am now just getting into building motor/etc. I am sure mistakes will be made, we all have to start somewhere haha.
What is the best (cheapest) route to go on about this? Purchase a not running motor and rebuild or buy a working motor and rebuild? This car will NOT be daily driven so I will barely put any miles on it. I am not looking to do any forged pistons or anything, just OEM performance will suffice.
I appreciate the feedback guys
Old Nov 11, 2014 | 01:48 PM
rudebwoy's Avatar
Default Re: B16A2 build
its been a while since I do anything 100% OEM, total B16 or N/A. I would recommend a known working motor. since it sound like you don't plan to force any induction. but a cheap easy build would be a D series. perfect for autocross.
Old Nov 11, 2014 | 02:00 PM
NotARaCist's Avatar
I never narc'd on nobody!
If all you want is OEM, I would stick to buying a known working motor. Also, for what you want to do with it, you might want to consider a different motor. The B16A2 is fun, revs to the moon, and makes good power while doing it, but it doesn't have **** for torque. Consider stepping up to a B18 variant, or even a B20, or B20VTEC hybrid.
Old Nov 11, 2014 | 03:58 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
What rules are you constrained by in your rally cross club? For autocross classing, you can stay in the same class with a 1.6L motor in a 96-00 EX, for example. So people use B16's instead of B18's to remain as a big fish in a small pond.
I find autocross mildly amusing. Not amusing enough to build a car around some stupid classing scheme that allows you 3 mins of driving per 8 hour day, though.
Rally cross seems like a lot of fun, though...mainly because I really REALLY like driving on dirt.
But...yes...use a known good motor and swap it in. Plenty of JDM swaps available all over the place...and you can buy one with a LSD trans option. If you need to stay within a class and a 1.6L is the requisite...then try a B16B swap instead. All of them come with LSD transmissions, and they make better power.
Old Nov 11, 2014 | 07:30 PM
jubile7's Avatar
Do you know exactly which D you'd recommend? I talked to the Rally instructor and he did say more torque is ideal.
Even if I pick up the known working motor, could I improve the performance and the reliability of the motor by rebuilding it? maybe swap out a couple of parts/clean it out/etc?
Thank you for reminding me. I just spent a little while reading up on the rules. I do want to stay stock, but there' sso many restrictions. Maybe swapping motor is not ideal, i will just need to pick a good motor and go with the chassis that will come with that motor (so it's stock by the manufacturs standard)
Old Nov 12, 2014 | 05:36 AM
jubile7's Avatar
is there a specific reason why B series are highly recommended? Why not H?
Old Nov 12, 2014 | 06:38 AM
EsotericImage's Avatar
Retired Moderator
Make sure you keep this thought in your head when you research the differences and what it takes to swap other engines.
Old Nov 12, 2014 | 09:22 AM
tony_2018's Avatar
Fish Twig
Read your first post, search up on what needs to be done to swap an h22 in, compare the price to swap in a B/D and then you get your answer.
Look up pro's and con's as well.
Old Nov 12, 2014 | 12:43 PM
rudebwoy's Avatar
I still think a d16z6 in a crx would do the job.
Old Nov 12, 2014 | 06:00 PM
joey1320's Avatar
A ZC would be fun too.
White_EK49
Dec 15, 2010 08:07 AM
R3DxLIN3
Jun 13, 2008 10:33 AM
96_cvc_ctr
11
Dec 2, 2007 10:11 PM
4thgenx42
19
Aug 18, 2007 10:52 PM
