Rotor comes loose
Old Nov 11, 2014 | 05:59 AM
David_S's Avatar
Default Rotor comes loose
Well yesterday while taking the kids to the movies my rotor came loose again. I had used blue locktite when I put it on originally but it still came loose. What do you do to keep this thing on
Old Nov 11, 2014 | 09:26 AM
4drEF's Avatar
Keyboard Humorist
Default Re: Rotor comes loose
I had that happen before.
I took the set screw out of the rotor and gripped it in a set of pliers.
With a really good squeeze, I intentionally damaged the threads a little.
After screwing it back into the rotor, the little bit of damage creates a better bind and holds in place.
Old Nov 11, 2014 | 04:53 PM
Riceburner247's Avatar
Alright, after trying to figure out if you guys are being serious somebody needs to explain this to me.
How can the rotor "loosen up" if it's sandwiched between the wheel and hub using tightened lugnuts?
Old Nov 11, 2014 | 09:36 PM
Grifty's Avatar
I think he means the dizzy rotor?
Old Nov 12, 2014 | 05:26 AM
David_S's Avatar
yes the distributor rotor.
Old Nov 12, 2014 | 06:08 AM
Grifty's Avatar
Thats really odd that it's happening, I'd try locktite again but a stronger strength and screw it in as hard as physically possible without rounding it.
Old Nov 12, 2014 | 06:35 AM
EFvtec Yo!'s Avatar
I had this issue before and blue (medium strength) Loctite worked for me. You could try the red (high strength) but you will have a good time trying to take it off when it does come time to change it.
Old Nov 12, 2014 | 08:38 PM
Old Nov 14, 2014 | 11:10 AM
Former User's Avatar
Originally Posted by Riceburner247
Haha
Old Nov 16, 2014 | 03:31 PM
KevinEF7's Avatar
Blue loctite with the appropriate time allowed to cure will never come loose under normal use, red will also solve it but be ridiculous to get off in the future
Old Nov 17, 2014 | 08:06 PM
schueytenten's Avatar
I thought the SAME thing....LOL
96teggynonVtec
Jun 12, 2016 03:38 PM
218luder
Feb 7, 2008 08:39 PM
Black R
Jul 9, 2005 12:46 PM
type r 01-1063
May 3, 2004 09:23 PM
quikrpm'z
Jul 17, 2001 08:04 PM
