2007 accord turn signal and hazard lights not working please help me
I have a 2007 accord 4 door, I had the issue of the flasher relay making the buzzing noise, so I went ahead and pulled it out and inspected the circuit board within the plastic housing,everything on the circuit board looked ok, but I plugged it back up without putting it back into it's plastic casing and I wound up inserting it incorrectly, and ever since I have no turn signals and no hazard lights,
I even put in a new flasher relay and it doesn't do anything,
So I'm thinking, did I short a wire? Ruin some kind of electrical component? Bcm maybe?
But the fuse within the engine bay is still good, even though I put the relay in the wring way it never blew the fuse,
Does anyone know where I should start? Or know what electrical component I should look into, I can't drive without turn signals for too long
As a side note, everything else in the car works fine, just these 2 lighting systems don't, since the fuses are good, I believe it's safe to assume it's not a shot in the wiring?
Is there any diff. In getting one from Honda or is te autozone one good enough? It is exactly the same and also says omron on it as well, along with the same voltage specs
So I have found the factory service manual online I will post up the link so every one here can use it, and it's strange but the circuit that's controls the turn signals and hazards is actually located within the wiper switch
Update i have solved the problem, it was the micu, i changed it out for another one and everything works as it should, pretty to install as well,
JDM Projects
Jul 26, 2011 06:18 PM
premo_si
Aug 5, 2006 10:07 AM
