vacuum line for vacuum gauge?
Hi all. Im trying to install a vacuum gauge for my b18b1. I tried the charcoal canister to throttle body line, it barely read -2 on the gauge, so i tried to run the line that comes from the back of the head and goes into the intake manifold, and i get -3 on the gauge, inches of mercury. am i doing this right? or is my gauge faulty.
what line do i tap into if those aren't correct?
notaracist, thats what i did. i believe its the pcv valve? its only a 1/4 inch vacuum hose, comes out the back of the head towards the center, and attaches into the very front of the intake manifold. i just tucked all the wires and hoses away and im gonna go on a test drive, but im upset that this isn't working well
...The PCV valve? You realize that's...no, of course you don't. That's a one-way valve. You can't use that. Use a VACUUM LINE off of the intake manifold. Your fuel pressure regulator line will be easiest.
okay so i hacked up my pcv valve line, can i just let it vent to atmosphere for now until i can get to a parts store to replace it?
okay i got a new pcv line, hooked it up, then tapped into the really thin vacuum line that goes into the bendy piece on top of the fpr. the other end runs into the manifold.
now its sealed up tight but only reads -10 on the gauge ALL THE TIME, whether at WOT or decel. im so confused.
it says keihen NR-1 on the housing of the thing i hooked the line up to. I googled that and it's a japanese FPR, so i know I hit the right vacuum line
It's neither. I custom rigged the spot where the cruise control button used to be, widened it out, wired it up to ground and accessory positive, wired the gauge up, fed the hose through the firewall, routed it up behind the steering wheel and connected it to the gauge, and pushed it into the dash.
eH.
So the vacuum line wasn't loose, or kinked or anything. However i noticed that when i went to pry the gauge out, the neeedle fell to 0 immediately. i started the engine and it stayed at ten. i then messed with it a little bit and figured out that the plastic cover for the gauge is probably rubbing against the pivot point on the needle, if i pry it out a little bit it rotates freely! At idle i get the following readings on an 165000 mile engine:
WOT = 0
semi-warm idle = roughly -16 steady
part throttle = somewhere between 0 and -16
WOT = 0
