help reverse lights not working.
Old Nov 10, 2014 | 12:25 PM
tercelrcr's Avatar
Default help reverse lights not working.
Hey guys so I just purchased a new 95 civic with a manual transmission. I noticed about two weeks ago that the reverse lights do not work. I replaced the bulbs still nothing. Replaced the switch and still not working. I checked the fuse hopefully it was the right one and it was good. There is no power at the reverse switch. So I guess my question is any ideas what the problem is or how to just run a new power wire to the switch? Any and all help is appreciated
Old Nov 10, 2014 | 12:28 PM
tony_2018's Avatar
Fish Twig
Default Re: help reverse lights not working.
Which fuse did you check?
The previous owner probably did an auto to manual and didn't wire in the reverse light. You might have to wire that one in. Shouldn't be hard. Can you confirm if there is a rectangle plug in your consoler where the shifter is?
Old Nov 10, 2014 | 12:37 PM
tercelrcr's Avatar
I can check but as far as I know the car is all stock. Where abouts is the plug
Old Nov 10, 2014 | 12:51 PM
tony_2018's Avatar
Fish Twig
Old Nov 10, 2014 | 12:58 PM
tercelrcr's Avatar
It was top row numbered 15 on the fuse box
Old Nov 10, 2014 | 01:07 PM
tony_2018's Avatar
Fish Twig
I was in the "RonJ' mode today. Take a look at the diagram, its specific to your yr model.
Old Nov 10, 2014 | 01:21 PM
tercelrcr's Avatar
Ok i will take a look for both the rectangle plug and also double check the fuse. As a LAST RESORT could I run a a hot wire from the battery to the yellow wire at the switch harness? I know it's not the proper way to fix the problem is why I ask
Old Nov 10, 2014 | 02:06 PM
Former User's Avatar
This^
If the cluster gauges and turn signals work, fuse 15 is fine.
Old Nov 10, 2014 | 02:22 PM
tony_2018's Avatar
Fish Twig
You shouldn't, if you do than your backup lights might stay on will be constantly.
Old Nov 10, 2014 | 07:59 PM
tercelrcr's Avatar
So I checked and there is no rectangular plug by my shifter. Also checked the fuse again and it is good has power going to it and leaving it but it's not making it to the switch
Old Nov 10, 2014 | 08:00 PM
tercelrcr's Avatar
Gauge all work and turn signals work as well
Old Nov 11, 2014 | 02:35 AM
tony_2018's Avatar
Fish Twig
Come on man, I gave you the diagram so you can check the wiring, check continuity from the switch all the way to the fusebox.
Old Nov 11, 2014 | 08:30 PM
slomofo's Avatar
GDD Member
This may come as a shock to you, but not everyone knows how to read wiring schematics. I have the same car as the op and am experiencing the same issues, but to me, your wiring diagram looks like blueprints to a nuclear bomb.
Old Nov 12, 2014 | 02:06 AM
tony_2018's Avatar
Fish Twig
Check continuity from the fuse box (Yellow wire) to switch.
Check continuity from switch (green/black wire) to reverse lights.
Check continuity from reverse lights (black wire) to ground.
To check the yellow wire you can start at the engine harness, from the switch to the driver side plug, than from driver side plug to fusebox
Do the same for the green/black wire, from switch to driver side plug, from driver side plug to reverse light.
For the black wire to reverse light its basicly from the plug to ground.
Old Nov 12, 2014 | 05:59 PM
tercelrcr's Avatar
so i was looking and i just wanted to make sure this is the right plug you are talking about to check. is it the one i circled? I want to make sure before i go messing around with any wiring since its not my strong skill and do not want to ruin any thing else.
Old Nov 12, 2014 | 06:45 PM
Mikepsedan_00's Avatar
This is what I did to my little brother's 89 hatch that had a similar problem. Might work for you, might not, I'm just putting something out there that worked for us. Someone had torn out the wiring before we got the car. The plug was still there with little stubs, but nothing beyond that. We ran a hot wire to the switch and put an inline fuse on it, then ran from the other side of the switch to the reverse lights and then from reverse to ground. It was simple, we got it done in about 20 minutes with a full interior car, and it was ready for chp inspection. Passed with no problems, and we never had trouble with it. He used that car for about 4 years after and never had an issue. The lights came on when they needed to and stayed off when they didn't need to be on. Problem solved. Hope it helps
Old Nov 12, 2014 | 06:51 PM
If you're getting power to the fuse, but not to the switch, you can wire from the fuse straight to the switch. Should take care of it, considering there's no breaks between the switch and the reverse lights
Old Nov 12, 2014 | 08:03 PM
tercelrcr's Avatar
I was considering this option. What size fuse did you guys use?
Old Nov 13, 2014 | 05:10 AM
tony_2018's Avatar
Fish Twig
Probably so. I think I see the green wire showing in the image. Both the wires run to that location but only one runs to the fuse box. Once you confirm continuity than you need to see why that fuse outlet is not feeding it power through the fuse. Be sure to check for continuity betwee the legs on the fuse as well, it may look good but its probably not.
You're not making any major changes, you're just tracing wires by sticking the probe on opposite ends to check if its the corrrect wire.
Old Nov 13, 2014 | 07:58 AM
10amp.. but you said you're getting power to your fuse right? If so, you don't have to put your own fuse in, you can just wire from the reverse light fuse in your fuse box. Just find out which is the hot side, and wire in to the opposite side.
Old Nov 21, 2014 | 01:19 PM
tercelrcr's Avatar
Ok so I now have power from the switch to the wire harness on the driver side. It has power in and coming out of the plug but there has to be a brake somewhere inside the car because there is no power making it to the rear. What is the best way to run a new wire from the plug to the reverse lights?
tercelrcr
Lighting
Nov 24, 2014 08:31 AM
notoriusaman
Honda Civic (2006 - 2015)
Jan 14, 2011 12:25 PM
brandon43
Mar 5, 2009 09:28 PM
fwdftw
10
Jul 24, 2006 05:31 PM
cvcrcer
Mar 31, 2005 06:04 PM
