Any guess on my compression ratio?
Old Nov 10, 2014 | 11:02 AM
CRXR's Avatar
Default Any guess on my compression ratio?
I did a static compression ratio on my lsv and results where between 240-250psi on all 4cyls....i was thinking around 12.1 maybe?
Old Nov 10, 2014 | 08:03 PM
m4xwellmurd3r's Avatar
You did a dynamic compression test. Static just takes cylinder volume , combustion volume, and gets a ratio between bdc volume and tdc volume.
A compression test like you do with a gauge is a dynamic test since it also takes the camshaft timing into consideration, which can change the overall compression.
Old Nov 10, 2014 | 08:11 PM
holmesnmanny's Avatar
My h22a gets 260 across and has 10.6
Old Nov 11, 2014 | 02:36 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Any guess on my compression ratio?
It might help if you list your setup.
Old Nov 11, 2014 | 04:03 AM
KevinEF7's Avatar
14102947398578120948.44 : 1
Old Nov 11, 2014 | 04:06 AM
F22Master's Avatar
Will he be ok on 93???
Old Nov 23, 2014 | 10:45 AM
CRXR's Avatar
Setup is
B18b block
Weisco 12.1 pistons
Je rods ...stock LS length
Stock B16 head
Cosmetic LSV headgasket
Bloxs Flat Racing Valves
Supertech Valve Springs
Stock LS crank
Blox Type C cams
Old Nov 24, 2014 | 07:14 AM
turbodcxbro's Avatar
My guess would be right around 12:1 since you specifically ordered and installed 12:1 pistons
Old Dec 22, 2014 | 12:31 AM
CRXR's Avatar
I run e85
Old Dec 22, 2014 | 12:32 AM
CRXR's Avatar
Might be higher since i run flat valves
Adam_b16a
Nov 30, 2009 08:29 AM
zoom545
Nov 22, 2005 09:04 AM
pootie.teng
Jun 2, 2005 10:32 PM
Btothe3rdDegree
Nov 14, 2004 01:44 AM
