P28 D16Y8 HELP
Old Nov 10, 2014 | 10:32 AM
dosstraflamus's Avatar
Default P28 D16Y8 HELP
I've recently decided to install a chipped p28 on a stock d16y8. However the car runs terribly. It accelerates slow, it wastes a lot more fuel and the car shakes a lot. It does have a y8 basemap.
Before I installed it, I've been told I needed a new throttle position sensor. With that being said, i told my tuner exactly this and he said once I replace the tps, the car should work fine. Is this true? Because I've also read that p28s don't run well with stock y8s. Any help would be appreciated. as a side note, my 2step sounds a lot different than my friends 2step (he however drives a dc5) any reason why?
Old Nov 10, 2014 | 10:33 AM
tony_2018's Avatar
Fish Twig
Default Re: P28 D16Y8 HELP
Whats wrong with the original ecu that you had to get a chipped p28 with the exact same basemap?
Old Nov 10, 2014 | 10:44 AM
Former User's Avatar
Originally Posted by tony_2018
Whats wrong with the original ecu...?
This^
A lot of time and money for what?
Old Nov 10, 2014 | 10:54 AM
tony_2018's Avatar
Fish Twig
Well thanks for adding additional information.
Fix the tps.
Old Nov 17, 2014 | 05:05 AM
Just because I wanted a 2 step and vtec engagement earlier. I fixed the TPS and it still acts weird. My idling ha high and was told it was the iacv.
Old Nov 17, 2014 | 05:09 AM
tony_2018's Avatar
Fish Twig
Put the original ecu back in and see if it does this, by doing this you can rule out if the p28 is the issue.
Old Nov 17, 2014 | 08:09 PM
EsotericImage's Avatar
Retired Moderator
I still dont know why people are consistently brain washed on P28 ECUs when they dont need a 28 map.
Guess another one learns the hard way. Your "tuner" is just there to take your money. Trust me.
Old Nov 24, 2014 | 07:31 AM
It actually runs a bit better now with the p28. I switched back to the stock one and it ran even worse. I'm in the process of cleaning the iacv and will see if it will run back to normal
SovXietday
64
Jun 11, 2019 06:42 PM
Alicali
Aug 18, 2017 08:03 AM
ngarover
Feb 8, 2015 08:04 AM
V-tec_91_Hatch
Engine Management and Tuning
19
Nov 30, 2012 07:07 PM
honda_turbo
Apr 2, 2006 09:43 AM
