EG/D16Y7 swap with stage 3 Bullfrog cam/P06 ECU - trouble staying running
What's up guys, I'm new here and just finishing up my first Honda swap. It's a 1995 eg 5 sd that had the stock D15 in it, I pulled that and installed a built D16Y7. I'm having trouble getting it to stay runnig. I'm using all my factory wiring harness and the D15 dizzy as well. The motor is built with a stage 3 bullfrog cam but I don't know the exact specs on it. I can't get the timing anywhere close to where it needs to be. Any thoughts or input? Thanks in advance guys!
Well, the head is probably a match for a D16Y7. You'll need to figure out the current cam or swap in a cam from a D16Y7 head.
The guy I purchased it from said it was running great in his car when he pulled it. (Yes I know how that goes). Is there any tuning that can be done to the ECU to correct any of this or is it my distributor?
Hmmm. That's some quality info. Thank you for that. Would it help any if I posted a video of how its running and what it's doing?
Ohhh gotcha. Mechanical timing is on point then it looks like because that's how my marks are lined up. I'm defintitely gonna double check tomorrow though.
If that's good, then check the ignition timing with a timing gun. See procedure in the FAQs sticky.
There is some vital bits of information missing here in my opinion.
You have a D16Y7 motor (OBD2) in an OBD1 car with an OBD1 ECU.
You didn't specify what you did to get the wiring hooked up. By that I'm mainly thinking the injectors.
Basically you didn't specify if you swapped the OBD1 fuel rail and injectors to the Y7 motor or if you are somehow running the OBD2 injectors of the Y7.
With a stage 3 cam (very aggressive) I don't see how the stock D15B7 ECU (P06) will run it well no matter what.
You need to get that ECU chipped and then tuned for the motor. Stage 3 typically is track orientated car meant for all top end power.
If the D16Y7 is stock head and block (not a mini-me) I am not sure why there would be a half a tooth off unless it has something to do with the D15 distributor. The thread Ron mentioned that talks about a half a tooth variance seems to be by using a stock Z6 cam in the Y7 head. I would think a stage 3 Y7 cam would have the appropriate timing for the Y7 head. Then again, who is to say what stage 3 cam is in the engine.....
I tend to think that trying to run stock D15B7 maps on a race built D16Y7 motor is the major problem. That's my initial thoughts on it.
Here is a bit from googling:
This is the stock cam lobe height:
And this website gets into the math and explains why high intake lift hurts low rpm (basic running of the motor) performance:
High Performance Math
Quote from that website:
Now I could definitely be wrong on your situation but to me it looks like the ECU can't make up for the regular low and mid range operation of the motor due to the extreme stage 3 cam profile.
Also of note, most Stage 3 cams are for vtec motors but there is always the possibility for custom stage 3 camshafts for non vtec if you are willing to shell out the dollars.
Being you don't know what motor that stage 3 cam is for, you may need an adjustable cam gear to get it timed. But it will likely still run poorly unless your ECU is chipped and has base maps for the aggressive cam.
After rereading the thread a few times, I think the mechanical timing is probably correct but the ignition timing is probably off due to the difference in the D15B7 distributor over the D16Y7. Good to know the B7 dizzy will bolt up but sounds like it's off mark in comparison. I don't think an adjustable cam gear is going to fix that.
I wonder if ignition timing can be tweaked by a tuner? I can't say I know a whole lot about the tuning process. If it can be it will also fix the low rpm issues you would normally have with the P06 ecu running a stage 3 cam.
BLOX Racing offers different stages of performance, Stage 1, 2 or 3, for the 1992-1995 D16Z6 and the 1996-2000 D16Y8. Now SOHC VTEC enthusiasts do not have to fumble with a one-fit cam and figure out if the cam needs to be advanced or retarded to fit.
Stage 1 = stock – mild
Stage 2 = mild – mildly modified (valve springs required; head porting highly recommended)
Stage 3 = heavily modified - full race (requires valve springs, head porting, high compression and ECU tuning)
BLOX Racing recommends upgrading to its high compression valves, heavy duty valve springs, and Ti retainers on certain applications.
D-series Stage II SOHC VTEC Camshafts Specs:
Intake (lift / duration) 0.432" / 235
Exhaust (lift / duration) 0.436" / 223
D-series Stage III SOHC VTEC Camshafts Specs:
Intake (lift / duration) 0.442" / 239
Exhaust (lift / duration) 0.468" / 226
Intake valve lift is determined by the height of the intake lobe on the cam. When you set the lift, you are setting the height of the intake lobe on the cam. Intake valve lift, intake valve diameter and intake valve duration determine air velocity in the intake system. High lift, large diameter and long duration all cause the engine to breath better at high rpms, but also cause the air to move slower at lower rpms, which reduces power at lower rpms. Low lift, small diameter and short duration all cause the air in the intake system to go faster, which increases power at lower rpms, but chokes air flow when the air velocity reaches the speed of sound. The speed of sound is 767.58 mph (miles per hour) or 67547.4 fpm (feet per minute).
I'm using the injectors that came with the motor. I wanna say they're 450cc's but I could be wrong. I just spliced the OBD2 connectors to my factory wiring to plug the injectors in. I was definitely thinking I'll need a Y7 dizzy too, and getting this thing chipped and then tuned definitely makes sense as well.
I am doubtful but is there any other places you hard wired?
I am not sure getting a D16Y7 dizzy is your solution. You would have to hard wire it too as it's not OBD1.
I think your fix is simply a tune like Tony mentioned. Which of course means you need to chip your P06 ECU. You could call a tune shop and talk to them to see if a tune can correct ignition timing.
