P28 + Neptune + 02 ?
Old Nov 9, 2014 | 04:25 PM
sixstroke's Avatar
Default P28 + Neptune + 02 ?
Hey guys, I've got a chipped P28 and I'll be using Neptune RTP to tune with once my project is running.
I've got a Prosport EVO Wideband O2 and I am unsure as to how I am supposed to have the O2 communicate with the ECU, so that I may log AFR's.
I've found some help online, but nothing definitive and I was hoping someone has been in this boat before and could show me the way.
Thank you!
Old Nov 9, 2014 | 06:46 PM
Muckman's Avatar
Moderator in Chief
Default Re: P28 + Neptune + 02 ?
The wideband usually replaces the primary O2 on D14. If you look at the Preferences in Neptune you will find where you can specify which pin for the wideband input.
Old Nov 10, 2014 | 05:11 AM
spAdam's Avatar
Loved
Community Favorite
You have to modify the ecu to use D14, it won't read the full scale as is.
OP, have you watched the NepTune help videos and read the input FAQs on the HRTuning forum? All of this is covered in detail there.
Old Nov 10, 2014 | 01:32 PM
sixstroke's Avatar
I've watched some videos, however, I don't recall coming across one that talks about this.
D14 you say? I'll look into both that and the video that I'm apparently missing.
Thanks guys!
Old Nov 11, 2014 | 05:36 AM
HRTuning's Avatar
Help>Working with Air/Fuel and Setting Up A Wideband.
Old Nov 11, 2014 | 12:51 PM
sixstroke's Avatar
Completely looked past that.
Thank you.
Old Nov 11, 2014 | 02:44 PM
HRTuning's Avatar
No problem.
ef9allday
Mar 22, 2013 09:46 PM
ekcivic2
Engine Management and Tuning
Jun 19, 2010 09:59 AM
variable
Oct 16, 2009 01:59 PM
eg6206
10
May 3, 2009 06:48 PM
Used2beAb16
May 15, 2005 09:31 AM
