Honda Civic HX ringing sound
Hey guys
I was hoping you'd be able to help me diagnose a strange sound coming from my car. I've done some work to isolate where its coming from. It happens in the following situations:
3100rpm only
Every gear
Off throttle only
About my car...
1997 hx 5 speed 212k miles
Good maintenance record and I have owned it for 8 years
Clutch has not been replaced since I bought it (@129k miles)
All other time sensitive parts (I.e. timing belt, water pump) have been replaced)
Burns almost no oil
No leaks, fluids OK
Basically I am thinking this has to be either a bearing on the output shaft of the engine or the input shaft of the tranny. Its also possible its a badly worn clutch/flywheel that's experiencing resonance at that particular engine speed. Let me know what you think.
Thanks in advance.
3100rpm only
Every gear
Off throttle only
About my car...
Burns almost no oil
No leaks, fluids OK
Thanks in advance.
Monstrositybl
Feb 11, 2016 01:47 AM
bloodyace05
Jan 26, 2016 03:10 PM
Grape Ape Guy
Apr 16, 2015 09:32 AM
