How to test whether 6 yr old battery should be replaced?
Easiest way is to take it to Autozone, OReillys, Advance, etc and have them check the cold cranking amp capacity, and overall health.
How old is it?
How old is it?
I can't find the Honda OEM CCA specs for that year, but new batteries are in the 500-600 range for CCA. If yours tests to within that you should be OK.
The diagram in my post states that 405-410 CCA is needed, so I think 449 CCA is good for now. Given that the battery is 6 years old, have it checked again in 6 months.
Was the test load capacity #1 done?
The way the shop tested the battery was using a battery tester which they hooked up to the battery while the engine was off. They inputed into the battery tester 500CCA, it ran the test and it gave me a print out which says: Voltage 13.08V, Measured 449CCA, Rated 500CCA, Tempearture 31 degrees Fahrenheit. It took them about 30 seconds to do the battery test. Is this the proper way of testing the battery?
It's described in the diagram I posted.
The test measures the battery's voltage after subjecting it to 2 consecutive 15-second load tests of 300 amps and 200 amps. If after these load tests the voltage drops below 9.6V, then the battery is bad or low on charge.
6 years is getting about to the end of the lifetime of a car battery, esp. if it needs to survive winters; this has been my experience.
Josh1987
Honda Civic (2001 - 2005)
Sep 29, 2017 09:38 PM
