How would I bypass the VTEC oil pressure switch
Old Nov 6, 2014 | 04:52 PM
DoHc-'s Avatar
Default How would I bypass the VTEC oil pressure switch
Ok how would I go about bypassing the vtec oil pressure switch or if I even can I got a jdm b16a pr3 obd0 ecu in my rex just wondering how to bypass the VTEC oil pressure switch
Old Nov 6, 2014 | 05:23 PM
F22Master's Avatar
Default Re: How would I bypass the VTEC oil pressure switch
Why? It's there for a reason...
Old Nov 6, 2014 | 07:12 PM
Bently_Coop's Avatar
Steve at Heart
You need an engine management system that can disable it. Hondata, AEM, Neptune would work.
Old Nov 6, 2014 | 07:24 PM
MOE@Hyper16Valve's Avatar
Icon6 Re: How would I bypass the VTEC oil pressure switch
It can be done by jumping a4 and d6 if i remember.\
BUT WHY don't you just GOOGLE it.
Just a side NOTE it's there for a reason.
Old Nov 7, 2014 | 10:08 AM
crx_si-r's Avatar
Correct. Just space both vtec solenoid and oil pressure wires together
Old Nov 8, 2014 | 08:18 AM
DoHc-'s Avatar
Yes I know it's there for a reason just wanted to know how because I bought a new pressure switch and it's still throwing the oil pressure switch cel wires are good and everything I don't know what it could be
Old Nov 8, 2014 | 11:01 AM
24TEN's Avatar
PHANTOM MENACE
Did you reset the ECU?
Old Nov 8, 2014 | 11:26 AM
DoHc-'s Avatar
Yes I have reset the ecu that's why I'm confused
Old Nov 8, 2014 | 02:28 PM
crvtectim's Avatar
Are you sure you're reading the code correctly?
Old Nov 9, 2014 | 03:32 AM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/hybrid-engine...rk%22-1812135/
Old Nov 10, 2014 | 01:02 AM
DoHc-'s Avatar
Yes 2 long blinks and 2 quick blinks.22
barone
25
Aug 20, 2009 08:32 AM
jdmsiR20
35
Apr 3, 2005 01:32 AM
