89 lx sedan injector issues
Old Nov 4, 2014 | 04:52 PM
89hondalx's Avatar
Default 89 lx sedan injector issues
To start I bought this car last week so this issue is new to me as are Hondas in general. It's a 89 honda civic sedan stock everything 1.5 dpfi. It's throwing code 16. I re soldered the main relay as well as tried swapping a new one in. The aux injector does work but the main doesn't. The main will work with the aux plugged into it but neither will work with the main plugged into either. I also tried a different ecu to no avail. It runs off the aux in limp mode and won't go past 4000 rpm. While running I checked and I have power on one wire at the main plug so idk what to do now
Old Nov 4, 2014 | 04:54 PM
89hondalx's Avatar
Default Re: 89 lx sedan injector issues
I forgot to mention when i bought it it wasn't running we found the screw for the rotor in the cap and it was 180 deg out. So idk if that happening while running could fry something else
Old Nov 6, 2014 | 05:39 AM
innes887's Avatar
Well if you have power on the primary injector that's a good sign, but now you need to see if there is a pulsed ground going to the other wire. Either you can pick up a noid light or grab a 194 bulb and straighten out the pins then put the bulb into the connector. You should see it flash if there is a pulsed ground and a constant power on that connector. If no pulse, check to make sure you have continuity from the non power wire all the way to the ecu. Sometimes the wire breaks after the pin so you may need to pierce the wire to get an accurate reading.
Old Nov 6, 2014 | 02:17 PM
89hondalx's Avatar
I have power at both but only the aux injector will fire. Does anyone know which pin on the computer goes to the negative wire on the main injector?
Old Nov 7, 2014 | 06:44 AM
innes887's Avatar
A5 & A7 are both primary injector signals
Old Nov 27, 2014 | 01:11 PM
89hondalx's Avatar
I jumped from a2 to the main injector wire that doesn't have power. When I did that it still threw code 16 and wouldn't start at all. Normally it starts in limp mode
Old Mar 5, 2015 | 02:16 PM
89hondalx's Avatar
Does the ecu send identical signals from both of these pins? If so where do they tee together since there is only one wire at the injector for ground
linkdeezie
Apr 10, 2013 09:39 AM
SweetDA9_TR
May 1, 2009 09:42 PM
cslegacy
Feb 28, 2009 03:56 PM
draw
Jun 29, 2006 08:42 AM
