93' Del Sol EDM KY Model D16A9
Old Nov 4, 2014 | 01:20 PM
leillox88's Avatar
Icon7 1993 Del Sol EH6 DOHC D16A9 HM8
First off... Civics and Del Sols should have separate forums...
Anyways, i will add a writeup later but right now im just gonna upload some pictures... enjoy!
poor sol :'(
the rareness
leillox88's Avatar
Default some water and soap...
Old Nov 4, 2014 | 01:32 PM
leillox88's Avatar
Default Ashamed to say it but this was 2 yrs later...
i was just a boy, so ashamed right now... i could have done a lot on my own in that time if only...
Old Nov 4, 2014 | 01:33 PM
leillox88's Avatar
Default 6 months later and its finally out...
fak that shop, fak the service guys, FAK PUBERTY! also fak the police!
Old Nov 4, 2014 | 01:39 PM
leillox88's Avatar
Default Lasts touch ups!
swapping to rear discs.
all civic's and del sol's were imported with rear drums to venezuela so this mod is rare here, also when we were installing them we had the left trailing arm almost out but the bolting hole for the trailing arms bushing was broke/non'existent since who knows when! but the soldering guy in the same shop one who withhold my baby for years had some impressive skills and rebuilt it just like new...
taking its first full engine bath with soap and graphite since 2008! also full oil service.
replaced fuel filter and this is how it looks now after being thoroughly cleaned with engine cleaner, carb cleaner, kerosene and armor all-like silicone protectant..
Old Nov 4, 2014 | 02:15 PM
leillox88's Avatar
Default i still got some problems to fix... :S
troubles i need help with:
1st headlights low beam is nowhere to be found, i got 4 wires loose and only one of them gives me power for high beams :S
https://honda-tech.com/honda-civic-d...lease-2740660/
seems to be a ground problem??? i checked G01 and G02 aswell as G101 G201 and G301 they seem to be all good
2nd i got a problem with ECT/FITV/IACV/Thermostat/Fuel Pressure Regulator and i dont know what else i have to check... the engine starts fine when cold but after a while it sttuters and plain and simple fights to stay on but sometimes it loses and dies... it happened to me twice while driving in N but after i changed the fuel filter it happened while warming up... FITV and IACV needs cleaning but im not sure...
3rd i got some kind of JDM/EDM or whatever plugs for fogs and turn signals are the rarest but i found just 1 picture that showed me how to tell wich was for signals or fogs... i dont know how to wire them and it seems confusing from the pics i got...
04321-SM4-309
04321-SR3-308 *** 04320-SP0-E00
really confusing stuff
j
4rd and most important i got CODE 10 for the transtop roof (alternator? wtf! no cel code for it)... i dont know where to begin since all the threads i found on delsolowneruk ended without solving the problem...
so i still cant say its fully restored and would really appreciate any help i can get...
Old Nov 4, 2014 | 03:00 PM
tony_2018's Avatar
Fish Twig
Default Re: 93' Del Sol EDM KY Model D16A9
Oh ****.........he's got the trans top....
Old Nov 4, 2014 | 04:54 PM
leillox88's Avatar
hahahahaha thanks for reading, i said the same thing when i pressed the button and it didnt work!
the guy couldnt make it work (he didnt know how and also broke the trunk cilinder trying to get in manually ) he wired it direct for now...
Former User's Avatar
That would be like separating bacon from eggs.
Old Nov 4, 2014 | 05:27 PM
leillox88's Avatar
i know but the civic/del sol section has over 300k threads and is getting a little hard to find the right info
Old Nov 4, 2014 | 05:30 PM
tony_2018's Avatar
Fish Twig
Well.........there is a search function. Its there for a reason.
Old Nov 4, 2014 | 05:35 PM
Thank you.
Try a Google search with your search terms together with honda-tech.
Old Nov 5, 2014 | 01:54 AM
thor33620's Avatar
Default Re: i still got some problems to fix... :S
you could check the depression hoses on the manifold.
does it happen when you stop accelerating or at idle?
Old Nov 5, 2014 | 04:02 AM
tony_2018's Avatar
Fish Twig
When was the last time you've done a tune up on your ignition system?
Old Nov 5, 2014 | 10:33 PM
MisereNoire's Avatar
This was posted by me in a different thread but may help you anyway, a couple of links that contain Del Sol specific information, including the transtop service/repair. I personally have little experience with the del sols, aside from replacing my brothers passenger airbag and performing a tuneup on his Sol VTEC. good luck.
First link contains EDM fsm sections and 2nd link seems to be a random mashup picked from forums.
Link 1 <<here>>
Link 2 <<here>>
Old Nov 6, 2014 | 01:23 AM
thor33620's Avatar
the problem is that he's has a d16a9 in it. and del sol never get that one.
Old Nov 7, 2014 | 11:22 AM
leillox88's Avatar
thanks for helping...
@thor33620 actually i found out in the crx 92 workshop manual that this is a model KY UKDM Del Sol wich its, according to honda, an "exception model" ... about my problems i still have to clean the FITV and IACV (my throttle body was left unprotected while it was in the shop, around 3 years). i have confirmed it doesnt happen when its cold, it happens rarely but only when idling and has sometime running, it seems to get choked and my father told me it smells a bit like gasoline... i can hear a hissing sound after i shut him off(dont know about that) and i can see a crack on the isulation layer of a hose conecting to the thersmostat housing also the intake manifold has some really poor attempt of a gasket, how hard could it be to replace it?
also my ECT plug broke(the one on the right, right??) and i hacked one with really small terminals and some shrinking tube, maybe is not working because it need the plugs isolation?
what do those connectors do? mine are barely hangin on
https://honda-tech.com/honda-crx-ef-...-crap-3221486/
could this thread be helpful? he tracked the problem down to a "weakening headgasket"
https://honda-tech.com/honda-civic-d...-out-3164132/?
https://honda-tech.com/honda-civic-d...-load-3227664/
https://honda-tech.com/honda-crx-ef-...niter-2581960/
this is interesting...
@tony_2018
i havent done an ignition timing ever and i got him wrecked 6 years ago, it has been "functional" since january with 200miles or less on him since then i read that someone replaced its coil igniter or distributor and all dissapeared, maybe i got my timing off, i should check, but is it common that it gets thrown after a while?
@MisereNoire
thanks for the info i had downloaded everything in the first link and merged in the engine part from the 89 crx to match my del sol, nice random mashup, i got some info i pulled from forums too... i dont know if i can post them here? they're pdfs
mmunozem1
Jan 26, 2014 02:56 PM
Dertyghettokid
Mar 19, 2013 06:46 PM
redlined_b18c
Mar 13, 2006 03:15 PM
