I/H/E max performance...
I want to get the most out of my header, cold air intake, and cat back exhaust. To do things the right way I would need a dyno, software, and tuner even though they are just basic modifications, right?
For the Dollar to Power ratio, Spending 400-500 for ECU work, Tuning and Dyno time isnt worth the 10 hp.
But thats just me..
Now If you get a set of cams and valvetrain on top of your IHE mods.. Then your getting somewhere.
But thats just me..
That considered, if you are going to spend the money on bolt-ons in an NA Honda then you should get a tune otherwise the bolt-ons will only reach about half of their potential. The socketed P28 cost me about 100 and 250-300 for a the dyno tune netted around 50 BHP with just IHE on my set-up. However, that was on an H2B set-up and most bolt-on + tune NA Hondas might get 25 BHP if you are lucky. Still, to the person that is interested in "max performance" from his/her NA stock block, a tune is money well spent... otherwise the bolt-ons will not increase performance as much as they should. Now adding some cams and supporting valve train might get you around another 10-20 BHP, but that will easily cost an additional $1000 or so depending on what parts you go with and how much work is DIY (may cost more than double that in some cases)... which is still not very cost effective...
intake: k&n cone filter,velocity stack,3.5'' to 3'' piping
header: toda or hytech or their cheap replicas
exhaust: 3'' catlless
you WILL need chipped ecu and a tune anyway.
gearing can also make a nice difference if you are opposed to opening the motor up.
todahead has some good suggestions on parts. you will hate life with a 3" catless exhaust on an na motor for daily driver. especially if its a nonvtec
racingant
13
Apr 30, 2005 12:36 AM
