Car wont start
Old Nov 1, 2002 | 05:14 PM
xvracing's Avatar
Default Car wont start
My 1991 honda civic 4 door wont start.
It is backfiring throught the intake and the exhaust. It sounds like it is going to start but it backfires and stumbles. Does anyone know what it is?
Old Nov 1, 2002 | 05:34 PM
Malgerus's Avatar
Default Re: Car wont start (xvracing)
Maybe not getting enough gas or a strong enough spark?
Old Nov 1, 2002 | 05:43 PM
Hcivic88's Avatar
Default Re: Car wont start (Mr. S)
are you getting spark on all plugs?
is the gas getting to the front of the car?
fuel injectors firing?
also, is it DPFI or MPFI?
Old Nov 1, 2002 | 07:25 PM
xvracing's Avatar
Could it be a head gasket, or a piston/piston rings?
Old Nov 1, 2002 | 07:52 PM
89 CRX SI's Avatar
i doubt it let us know a detaileed dexcription of the problem and we can then help you.
Did this just happen overnight?
make sure every vacum lign,electrical connector is pluged in.
spark plug firing order right?
fuel pump priming
my guess is your plug wires are mixed up
Old Nov 1, 2002 | 08:22 PM
straightline's Avatar
check your codes
Old Nov 1, 2002 | 08:44 PM
MrTodd's Avatar
Default Re: Car wont start (89 CRX SI)
fuel pump priming
Agreed. First tell us the history/setup of the car! But I would think that the timing is off, when my timing belt slipped on my A6 motor and it died - every time I tried to start it, it would backfire quite a bit (not way loud tho).
Old Nov 2, 2002 | 02:19 AM
boostinb18's Avatar
Default Re: Car wont start (MrTodd)
fuel pump priming
yah give us an explanation.... it sounds like firing order is incorrect!!!
Old Nov 2, 2002 | 06:15 AM
020's Avatar
020
that's no moon
Default Re: Car wont start (boostinb18)
oe this didn;'t happen....
https://honda-tech.com/zerothread?id=322039
Old Nov 14, 2002 | 12:11 PM
xvracing's Avatar
The screw on the rotor came loose and fell off. The rotor wasnt spinning so there wasnt any spark. I put in the screw and tightened it up really good and the car started right up. I replaced the whole distributor about 3 months ago, and I guess I didn't tighten the screw enough.
biker jim
Honda Ruckus and Scooters
29
Aug 22, 2019 12:52 PM
Dilyla02
May 13, 2013 12:38 PM
about:blank
12
Jan 19, 2008 02:13 AM
oakpwr
Jan 20, 2007 06:00 PM
I3ackfire
22
May 14, 2004 09:50 AM
