Rad Fan Fuse blowing, but not with larger fuse...
Old Nov 1, 2014 | 02:21 PM
iwannarace's Avatar
Default Rad Fan Fuse blowing, but not with larger fuse...
Chassis is a 92 SI. Fan is a 12" Spal. The 15A fuse keeps blowing when the fan switch goes off, but I put a 20A fuse in instead of the 15A, and the fuse doesn't blow.
I know that's not the right way to fix this problem, but someone please explain why this works and why the 15A fuse is blowing in the first place. Thanks!
Old Nov 1, 2014 | 04:13 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: Rad Fan Fuse blowing, but not with larger fuse...
The fuse rating is typically half of the draw of the circuit. So a 15A fuse is protecting a 7A circuit. (more or less) Apparently your circuit is now loading up more than 15A,but less than 20A.
If you use a larger amp,you run the risk of starting a fire, as the fuse is designed to protect the wiring from overheating/melting/burning.
Old Nov 1, 2014 | 05:56 PM
iwannarace's Avatar
So to properly accommodate a larger draw, I should replace wires with larger gauge?
I replaced the stock rad fan with a Spal fan... Would this be the cause?
Old Nov 1, 2014 | 06:06 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Yes.
I dont know. I'd have to troubleshoot....
Old Nov 1, 2014 | 07:28 PM
hybridmiklo's Avatar
most likely the new fan draws more amperage, which makes sense since its a larger more powerful fan. Ensure the wires to the fan are the necessary gauge.
Old Nov 1, 2014 | 10:08 PM
iwannarace's Avatar
Awesome, thanks for the info!
demiseraph
Aug 5, 2011 05:12 PM
Aaron Cayabyab
13
Jul 22, 2011 09:15 AM
trustdestruction
Mar 30, 2009 06:58 PM
trustdestruction
Mar 30, 2009 03:11 PM
b00sted4dr
Jul 25, 2005 05:28 AM
