92 accord f22a6
Old Oct 31, 2014 | 10:57 AM
alex1992's Avatar
Icon2 92 accord f22a6
hey im having a little problem with my accord manual tranny.hope someone can help me out.say im in like 1st gear and I let off the gas the car jolts back and forth or when im in a higher gear and im slowing down it does the same thing until I give it gas then it stops.my motor mounts look good and Im not sure what it can be hope someone can help me out..thanks
Old Oct 31, 2014 | 12:53 PM
holmesnmanny's Avatar
Explain "jolts back and forth" better
Old Oct 31, 2014 | 01:39 PM
alex1992's Avatar
Default Re: 92 accord f22a6
well the car shakes back and forth.it feels like the engine shakes back and forth when i let off the gas.also this is out of topic but today i was bleeding my clutch and every time i held the clutch in to open the bleeder screw the clutch pedal would not return.i would pull it back out and it would return again normally.is this normal ???it only happened when i held in the clutch to open the bleeder screw.
Old Oct 31, 2014 | 05:07 PM
NerfGunner420's Avatar
open the bleeder screw and fill the clutch reservoir the air should leak by it's self. i have never bleed a clutch line by pumping the pedal after i had a few soft or spongy pedals. leaving the bleeder screw to let the fluid drain and never had a soft or spongy pedal ever!!!!!!!!!
Old Oct 31, 2014 | 05:30 PM
alex1992's Avatar
alright ill try that nerfgunner thanks for the advice.but im still having problems with the car shaking back and forth when letting off the gas while driving.feels like the engine shakes back and forth but the mounts are good so im not sure.?
mikegarcia2000
Sep 25, 2021 05:56 PM
2dooraccord
Nov 24, 2008 04:47 AM
K2MSL200
Dec 17, 2007 02:05 PM
