P0505 + lurching
98 civic ex, d16y8, MT, 150k
I've been having problems with this since I replaced my head with a re-manufactured one. When I lightly depress or release the gas pedal the car violently lurches as if slamming on the brakes/gas. This only happens once the engine is at operating temp, and can be fixed (while driving) by turning the car off and restarting. After about 5 minutes the problem starts again. The code it keeps giving me is "P0505 idle air control system".
Things ive done:
Replaced IACV (new not junk yard)
Replaced PCV valve and hose
Removed throttle body and sensors, cleaned throttle body thoroughly
Checked for vacuum leaks the best that I could
Reset ecu multiple times, P0505 is the only code and recurs each time
To me it seems like it may be an electrical problem due to the fact that a simple restart of the car fixes it every time. But I'm far from an expert so I could be wrong. Any suggestions?
Things ive done:
civicophy
Apr 26, 2024 10:18 AM
Andrew Ryan P
Mar 20, 2017 07:48 PM
crnimacak
Jan 19, 2006 04:59 PM
Blazin Civic
Apr 13, 2005 01:41 PM
