94 Civic slow crank, clicking, and wiper issue
Last night when I started the car it cranked over slow and I heard a clicking under the dash, but it started on its own power. This is after it has been sitting for a while. After driving it for a while and starting it back up it fires up right away with no issues. This morning however, it was slowly cranking and the clicking was occurring from under the drivers side dash. When the car started, the wipers were constantly on. Even after shutting the car off and starting again they remain on.
I know the main relay has to be good since the car does start and continues to run. What do you guys think it is? Perhaps it is just a bad ground? Or possibly a dying battery or bad alternator? Then the slow cranking just shorted something out messing my wipers up?
I am going to go check over the grounds and see if I notice anything unusual. In the meantime I would appreciate any input. Thanks!
Thanks for the input!
Cold weather always brings out weak old battery problems. the colder it is, the more prominent and old battery displays signs of age of not putting out the full Cold Cranking Amps (CCA).
Put a new battery in and the car starts right up. I have not had an issue with the wipers since the first incident and I hope it will not resurface!
hondamyheart
Mar 6, 2017 05:16 AM
waciii
Jan 15, 2009 12:49 PM
